Solar series battery charging problem
88 replies · 15K views · last reply
BernieM said:
Though I don't know what the frequency response will be on the meter in the a/c current mode, but I bet it's higher than 3000hz.
Scope reported 60 hz ? That's probably all you need.
BernieM said:
And the current can be tested into the μa with the meter I have.
If it's in series it'll have to pass the DC too. Most DMM's have a 2 amp fuse for the low ranges, better ones have a 10 amp fuse for that range.
So - Be careful you don't blow the fuse by asking it to pass ten amps or more of charging current..
Only external indication of blown fuse is it always reads zero on current scales.
Again - Good Luck , keep on eliminating stuff...
old jim
After a lot of study of the problem, I have come to a conclusion (wrong or right is yet to remain to be seen.) Let me posit it here, now.
No batteries are perfect, and individual cells have a small variation between them in total capacity. Electrons flow from the + terminal of a battery to the - terminal. Heat generated by current flow in the battery is seen first at the + terminal of the battery. Also it should be noted that most failures in a battery are positive plate failures, where negative plate failures are very rare. This is a quote of an article that addresses this: "
  • VLA (Vented Lead Acid)
    In VLA batteries, positive grid corrosion is the normal sign of impending failure. As the grid corrodes, the effective cross section of the conduction path narrows — and the internal cell resistance increases. At the same time, the grid structure swells and deforms, causing it to lose contact with the paste (active material). Because the resistance between paste and grid increases, internal cell resistance increases. If you ignore the increased resistance and fail to remove the battery from service in a timely manner, the positive grids will lose their mechanical strength and start to break apart. "
Here is a link to that article: http://www.ecmweb.com/content/why-batteries-fail-prematurely
Here is a list of the types of failures and how common they are for different battery types:
http://www.aandncaravanservices.co.uk/resources/Battery failure chart.jpg?timestamp=1489447048898
Elevated temperatures require temperature compensation, reducing the current flow as temperature increases in the battery. Even within a battery there is a small variation in temperature from the + end to the - end of the battery. (I am of course talking here about lead acid flooded cell.) This small variation will not create much of a difference in the life of the battery or charging it, if the battery is by itself (stand alone.) But in series and parallel configurations, this temperature difference becomes more important. I will now attempt to explain why:
In a series configuration, a small difference in temperature at the + end of the battery will cause the first battery to overcharge a bit, while the second battery does not overcharge, as the average voltage is what the charging device will see (average voltage of (battery 1 + battery 2.) ) At the same time, one of the cells in the second battery will be weaker than the rest of the cells (this is true of the first as well but since the first gets overcharged it does not become sulfated)
Because the second battery is getting a bit less charging, all of the cells in it will get a bit sulfated, with it's weakest cell becoming the most sulfated within it. Overall the entire battery has now lost a little bit of capacity, with one cell even weaker than the rest. With repeated discharge and recharging, this difference is amplified, and as it becomes weaker, the first battery becomes more and more overcharged with each charging cycle.
Ultimately it depends on just how large that difference becomes, whether or not it will reach it's expected normal life or not, failing prematurely. So basically as the 2nd battery becomes more sulfated, the first becomes more overcharged, and as it overcharges, it becomes hotter, adding further to the problem, which will eventually lead to a positive plate failure in the first battery, the most common type of plate failure, and the second battery in series becomes possibly ruined by sulfation.
In a parallel configuration, this becomes even more problematic, as in a normal parallel configuration with identical batteries, current flow through each circuit is equal. However when one battery becomes hotter and overcharged, the internal resistance drops lower than the rest of the battery circuits, allowing far more current to pass through it than the rest. This even further accelerates the degradation of the weak battery string. And since my array is 10 banks of 2 batteries in series, this would rapidly accelerate this mode of failure in a battery in my banks.
Excessive heating, or unequal heating of the batteries in the strings, is basically the culprit. Caused by a number of factors, including environmental heat and current flow into and out of the battery strings.
With a large number of batteries such as I have, one would also be concerned that one battery suddenly get shorted out and all the other batteries then discharging through it! This is one of the reasons I decided to build an underground concrete cellar for the batteries. Battery explosion containment. It also helps to maintain a lower constant temperature on the batteries being over 8 feet deep where soil temperatures are low even in the summer. I should be able to keep the batteries in the 70F - 80F range which is ideal for them.
A friend of mine suggested a water bath to set all the batteries into and use night sky cooling to cool the water. But I think the black body radiator would have to be pretty big. Will have to investigate that further, later.
I lean that direction too. Are positive batteries set on a shelf above the negative ones?
Water bath seems overkill i'd think a few small electric fans to encourage air circulation might be just as good.
Peak charging from your panels comes same time of day as peak heat. Some estimate of battery internal temperature where the plates are might be enlightening.
Rise above ambient we don't know. An old fashioned glass thermometer stuck down in top of a cell would tell you that. It could sit right on the top of the plates.
Wall-mounted glass thermometer with a red liquid column, scales in Celsius from -30 to 50 and Fahrenheit from 20 to 120, branded Stalwart.
Take two of these el cheapos, remove the element from one and put it in middle cell of middle battery ? Other one nearby for ambient ?
A thermistor dipped in that insulating plastic for tool handles stuck right down in the middle cell's electrolyte might give your charge controller a more accurate battery temperature .
Keep up the good work !
ps thanks for sharing in that other guy's DIY solar thread .
old jim
old jim
No, the pairs of batteries sit on the same level, with their posts ends next to each other. They should be approximately equal in temperature.
Air circulation where they are would just be the same hot air they see now, around 95F in the heat of the day. In the bunker (when it's finished) it would work because ground temperature there is around 75F in summer. I actually plan to set them on the floor there, not stacked at all. I have enough space for that (planned it that way.) That way each battery is sitting on the ground as a heat sink. A small fan will be helpful as well there.
Peak sun and peak heat are NOT the same here in Arizona. Max temperatures occur around 4pm or so, where max insolation occurs around 1pm in the summer (check out solar noon charts.)
One question I have yet regarding charging of batteries on solar is somewhat related to what has been discussed here:
During the desulfation process when you have raised the voltage to reverse the chemical reaction, is there a minimum amount of current flow required? Of course low current would make the desulfation process take longer, but would say .1A @ 30v be enough to desulfate a large battery? In other words, what is the optimum amount of current @ a given voltage for the desulfation process, or is there one?
This also goes along with the objection I had about the cells not using current. It was stated that the current flow in a battery in the cells is always equal. However since current is a fixed quantity of electrons (coulombs) as electrons are captured to reverse the chemical process (molecules share electrons and to separate them one has to provide the lost electrons) the total count of electrons flowing past a cell should be the total number to begin with minus those captured in the electrochemical process of desulfation. Therefore the coulombs of electrons moving to the next cell in the circuit is diminished.
It's a physical electron capture process, is it not? I don't believe that just providing sufficient potential is adequate unless somehow there is another source of electrons available for the chemistry to occur without reducing the quantity of electrons flowing. Personally, I think that you guys are thinking of a charger, that keeps the current at a fixed value, a constant current source. However in a solar charger, you are limited to the amount of current available from the panels. You can't get more than that. So each string would use it's portion of the total current available (resistors in parallel) and that would be the maximum amount that could enter any battery string. From that fixed quantity one has to subtract the electrons captured in the first cell, that will give a lower number available to the next cell.
This then is where I have an issue (and perhaps it is a misunderstanding) which I need clarification on. The only way that I can see that the current is kept constant is if one had an infinite (or excess) amount of power available, like line current for a charger.
BernieM said:
I also tried my clamp on ammeter but it showed no a/c as well.
What is the model of your clamp on ammeter? If you clamp it around the cable to the pair where the failures are occurring, what does it measure when you are charging? And what does it say when you have a substantial load on the inverter?
Also, does it read the same at the positive terminal of a series string as at the negative terminal of the string? How about the reading on the jumper between the two batteries of a series string?
Well that's the funny thing. As everyone has been telling me that current is equal throughout the whole battery, the other day toward afternoon when the max amps available for charging was around 10 amps or so from the array, I decided to use my ammeter in-line (not clamp on) with a pair of batteries. First I measured the amps going into the battery at the + connection and read 10 amps. Then I broke the wire connecting the first battery (+ connected one that I had tested) and put my ammeter in line there. 0 amps. In my apparently incorrect thinking on this subject, I saw it as the power being consumed by the cells and that until each cell was satisfied (charged) no current gets to flow to the next cell, all power first being consumed by the first battery and then when it was full on to charging the second, producing a battery that is lower in voltage than it's mate in the pair. Which fits the problem I have described. But this doesn't fit other battery pairs I see either. Some pairs are in fact both charged equally. So I think this 0A charge problem to the 2nd battery is indicative of some kind of a problem with the first battery. Which also fits with my original problem. That one battery gets overcharged, and eventually fails, while the other battery in the string gets undercharged and sulfated. But I can not reckon what it could possibly be as there is no complete circuit for current to flow without current flowing through the 2nd battery to ground!
The only possible way I can reconcile this is either it has to do with the chemical reactions that do or can take place in a battery (perhaps something that can happen when a cell has a certain type of failure?) or that my meter was not reading properly for some odd reason (bad meter, bad leads, poor connection?) when I connected it between the two batteries in series.
I unfortunately have not had time to revisit this test, but intend to do so today or tomorrow. But I want to put 2 ammeters in line, one at the + and one between the two batteries to get a simultaneous read, as well as show voltage. In that way if I do repeat the results I can take a picture of it and post it here. Either that or see that my original measurements were problematic and get a proper reading.
Just some cheap clamp on ammeter that a friend bought me from Harbor Freight. But it does work. I don't know it is sensitive enough however for small current flows. I will have to make the measurements to answer the rest of the questions. I think I have another pair in failure now, considering the results I saw recently when I did the current flow tests, so that will be a good pair to test and then to keep an eye on.
BernieM, I would highly recommend that you get yourself one of these: http://www.ebay.com/itm/LCD-Digital-Clamp-Meter-Multimeter-True-RMS-AC-DC-Volt-Amp-Ohm-Temp-Tester-D0K8/401215156842?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Until recently, low cost clamp on ammeters could only read AC current, but this one is an example of the low cost high performance clampons available today which can measure DC as well as AC. With one of these you could quickly measure the DC current (or AC ripple) in each battery during charge and discharge.
I saw these discussed on another forum and realized it could solve a problem that had been bugging me. I was experiencing a very slow discharge of the battery in my van so that in a week the battery would be dead. I bought a more sensitive one made by the same company: http://www.ebay.com/itm/True-RMS-AC-DC-Current-Digital-Clamp-Meter-Multimeter-2000Counts-UNI-T-UT210E-US/291374904701?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
The more sensitive one has a 2 amp full scale range and can detect mere milliamps of DC. I tracked down the vampire load in my van easily without having to cut or disconnect any wiring.
Disclaimer: I get no commission if you or anyone else buys one of these.
When you have large batteries, heavy duty (low resistance, in other words) cables, and multiple parallel and series connections among many batteries, breaking a connection to insert an in-line ammeter can change the way current flows in the whole arrangement distribute themselves. That's a good reason to have one of the clamp on ammeters I linked above. Using a clamp on you aren't disturbing the current flows by inserting the resistance of an in-line ammeter in the circuit. The clamp on gives you a way to quickly measure any of the currents without disturbance.
You asked me what brand I used to take the measurements. You did not ask me if I had other ammeters. To that, the answer is yes, a wide variety of them from DC clamp on ammeters made by Snap On, to wire it in and leave it type ammeters, meters that show alternatively amps, volts, watts, etc., a bench meter with an ammeter in it, two DMM's with amps in a variety of ranges, etc. I don't think I am going to be needing another one.
If taking a reading would influence the flow of current, then it would have equally disturbed such flow when I put it in line with the + terminal to the first battery as it would at the second battery in the series. Besides, ammeters are very low resistance, theoretically zero ohms. I am sure the resistance is very very low, and if an extremely low resistance would cause issues, then likewise any inductor in a clamp on ammeter that allows it to detect current flow (remember an inductor needs to have a changing field so they have to make a/c out of the d/c or pulse dc anyhow) then the collapsing field would induce a corresponding counter emf, which in turn would act like a small resistance, similar I bet to the very low resistance in an inline ammeter. But I don't really want to debate that here.
yeah, sounds to me like something opened up on ya.
I've had batteries break an internal connection. One car wouldn't start unless i pushed down on the post to make the internal connection again. It'd work the dome light and radio i guess through electrolyte but voltage collapsed with even the windshield wipers turned on.
We learn a lot in troubleshooting, among the most valuable is how little we know. I had to refresh my battery chemistry to keep up with this thread.
Here goes
a battery cell has two plates one of pure lead and the other of lead oxide. They are immersed in sulfuric acid which is a mix of hydrogen ions and sulfate ions.
The pure lead plate is the negative one
the lead oxide plate is the positive one
As the battery discharges,
the lead plate turns into lead sulfate and pushes electrons out into the external circuit, one by one, oops two by two
the lead oxide plate .turns into lead sulfate and pulls electrons in from the external circuit one by one also two at a time
no electrons get 'stored' or hide out inside the battery
Here's pictures from http://ecee.colorado.edu/ecen4517/materials/Battery.pdf
that i annotated a little bit
berniebatt1-jpg.206761
that allows pure lead there to become lead sulfate and push electrons out into the world.
And over at the positive plate, almost instantaneously,
two electrons (but not the same two) enter from external circuit per Kirchoff's Current Law.
berniebatt2-jpg.206762
That allows the positive plate to pull electrons in from the outside world.
Were electrons allowed to accumulate or deplete inside the battery it would soon have an excess or shortage of them and rise to lightning-bolt potential with respect to its surroundings. That's how lightning works in clouds.
Sulfate ions in solution get replaced by water molecules. Electron balance is maintained.
Of course for charging just revere the directionsold jim
Sounds like what I had in mind on battery chemistry too.
OK so you have a charging situation now, and the amount of current will be limited to the total resistance in the battery between the positve and negative posts. So each cell will appear as a resistor and since there are 6 cells, the resistance will be about equal in a normally operating battery so you have 6 resistors with value X. So the resistance of the battery is 6X and using ohms law, I=E/R which means the result will be I=V/6X. Now as a cell charges, the electrolyte regains sulfur ions, and becomes more conductive. In the process of gaining electrons, the only place from which to take those electrons is the current flowing into the battery. So now the cells become more charged, we have a new resistance internally in the battery, and now we have I=E/6Y (Y for the new resistance of the cell.) Putting real values in, let's just say X = 10 and Y = 5. So to begin with we had 100 ohms resistance (yes I know it's actually called impedance) and a voltage of a partially discharged battery at say 11.0V So I = 11/60 = .18A current flow into the battery. Later when it is charged up more we have I = 12.0V/30 or .4A current flow. So current flow increases as the battery gets charged, as well as the voltage increasing. This means as the batteries get charged up they are also producing more heat then. For me that translates to more heat at the end of the long hot summer day, at the same time the day has gotten the hottest. Bad news.
What I still do not know is, since the cells are in series, whether the first cell will consume more electrons than the next cell, and it more than the one after it, or if somehow all cells will somehow magically get the same current as stated early on in this thread.
If you look at the cells as individual batteries connected by a liquid connection whose resistance changes with state of charge of the battery, then from the + post to the first cell we see 1X resistance. From the first cell to the 2nd cell we see 1X resistance. But from perspective of the first post, we see 2X resistance to get to the 2nd cell. So the current, as I see it, is highest to cell one, and 1/2 that to cell two. But as cell one charges up, the resistance between the + post and cell 2 decreases, allowing then more current to arrive at the 2nd cell.
Are you seeing my confusion here and why I can't reconcile that all cells see the same amount of current at the same time?
Or another way to put it would be the old water pressure model, where voltage is pressure and amperage is water volume. You now have a hose with 6 holes in it, all the same size. As the water goes through the hose, some of the pressure is lost at hole #1 (but pressure is equal through the whole system unless the far end of the hose is open to the air,) as well some of the volume of water moving through the hose. Same for hole #2, etc., until at the end hole you have only the quantity of water flowing in the pipe at that location as the water that will flow through hole #6. So if one looked at it as gpm, and showed how much water was flowing in the pipe between holes, each hole draining 1GPM, before the first hole you have 6GPM going into the pipe. Between hole #1 and #2 you have 5GPM, 2#3, 4GPM, etc., until hole 6 at 1GPM.
This is driving me nuts. If you guys are right then somehow I have the wrong model of the internal workings of the battery, and all I can find on the Internet are basic explanations of batteries, nothing in depth enough to cover this adequately. Please feel free to point out the mistake I am making if you see it!
P.S. Regarding your Kirchoffs Current Law. The sum of the current leaving a node is equal to the current entering. However there is more than one path to leave the node. One path is electron capture to reverse the chemical process, and the other is conduction on to the next cell, correct?
I think you're grasping to hold on to an old misconception. It's human nature to do that.
If your pipe has no leaks,
every molecule of water that enters one end must exit the other end abeit at reduced pressure.
Gallons in = gallons out
divide both sides by minutes and gpm in = gpm out
but
pressure in ≠ pressure out
Yes if the pipe has no leaks. Each cell is technically a leak, as electrons are required to put the sulfur molecule back in solution as electrolyte, right? As I said above (you may not have read it since I posted it after you responded) there are two paths for the current. One is on to the next cell, the other is capture in a chemical reaction.
Wow you're making me go back to high school chemistry , i hope i get this right
When working equations for chemical reactions you have to balance not only atoms but charges too.
Note that when SO4 ion plates out on negative plate
Two-panel diagram of a lead-acid battery discharging: lead electrode with Pb0 atoms, sulfuric acid electrolyte with H+, SO4-2 and H2O, and a load connected to the positive terminal; the lower panel shows an SO4 ion leaving the electrolyte and two electrons leaving the battery.
The charge in the electrolyte appears unbalanced, at first glance. It lost two negatives and no positives. There's two unwed hydrogen ions now. Mother Nature won't stand for that.
She takes care of it over at the positive plate. It's a little sneakier there...
Diagram of a lead-acid battery discharge: top panel shows H+ and SO4 2- ions in sulfuric acid electrolyte moving toward a lead-dioxide electrode with two electrons arriving from the load; bottom panel shows SO4 bonding to Pb and H2O forming at the O sites.
Handwritten-style text reading: Electrolyte gained 4 negative charges (electrons) from the two oxygens, but only lost 2 from the SO4 ion, for a net gain of two negatives. Balancing the two negatives it lost over at the negative plate.
Note it used up 4 hydrogen ions here and only one SO4.
The ionized H2SO4 molecule consumed here donated 2 hydrogens, and the one consumed over at the negative plate donated the other two.
So, both atoms and charge are conserved.
To put it in fewer words -
an electron that jumps into the lead atom at + plate causes one to jump into the electrolyte aboard an oxygen ion
and causes another one to jump out of the electrolyte over at the negative plate .
Hydrogen ions are pretty much free to migrate in water. (Like everything else, it's not quite that simple - see https://chem.libretexts.org/Core/Ph..._Bases_in_Aqueous_Solutions/The_Hydronium_Ion)
The load completes the circuit .
Without a load, only enough electrons move to establish an electric field in the battery.
Were it not so Kirchoff would be wrong.
on balancing charge in chemistry equations:
http://www.periodni.com/half-reaction_method.php?eq=PbS+H2O2=PbSO4+H2Ohope this helps
keep us posted what you find
old jim
BernieM, if you have your in-line ammeter connected in series with the + terminal of a battery at the top of one of the 24 volt series strings how does the measurement of the DC current compare with what your DC responsive Snapon clamp ammeter reads?
Assuming the readings are essentially the same (meaning we can trust the Snapon), without changing the setup move the Snapon clamp ammeter to the cable leaving the bottom of the 24 volt series string and get a reading of the current leaving the string. What are the two readings on the clamp ammeter?
Ahhh, Electrician i like your method. Make everything prove itself good especially your test equipment.
How many times have i got fooled because i didnt understand how my measuring instrument would respond to an unusual input.
Example: Some true RMS meters won't measure AC in presence of DC beyond voltage range selected - ie don't try to measure millivolts of AC riding atop ten volts of DC.
With clamp around meters one has to be really careful about DC.
Early electronic DC clamp-ons used an interesting technique, they had a feedback winding to which a feedback circuit applied DC to drive average flux to zero as measured by the Hall sensor. (That required power for the amplifier, my thirty year old Fluke takes four AA cells in the handle.)
What got reported is the amp-turns necessary to achieve that null, scaled of course to represent amps through the donut hole. My ancient fluke delivers 2 volts proportional to 20 amps..
It takes time to reach balance and that's why their frequency response was only out to a khz or so.
Moral of story: it's important to understand the working principle of one's test equipment. I like analog 'scopes and Simpson 260 multimeters because i understand them.
OK, first of all let me state that my measurement between the two batteries that was zero was apparently due to a faulty connection (as you recall the measurements I initially made were using my DMM inline on 20amp scale.) I checked it a few times but I guess I wasn't getting good continuity. Using the Snap On ammeter, I get decent readings. This meter has a full scale range of 100 amps, with 0 center. So it's 100-0-100. Now when I took a reading (early in the morning so sun isn't high in the sky yet and amps are still low) I get about 2 amps at both the + and - of the series battery pair. Odd though, at the - post and the common posts where the two batteries are connected, the reading is left of zero on the scale, where the reading at the + post is right of zero. I tested it at multiple locations on the wire and the result is consistent.
Very clearly worded - Thanks !
Only reason i can see for polarity reversal is
(no idea what yours looks like so take this as generic)
Photo of a red Snap-on EETA501C AC/DC clamp adapter with a black cable, annotated with red arrows showing current direction through the jaw, labeled DC clamp around meter, reads positive and reads negative.
Usually there's an arrow and + sign someplace on the meter indicating which direction of conventional current (not electron current), up or down, will give a positive reading..
old jim
I assume that all your clamp ammeters can read AC, but it looks like the Snapon is the best.
This afternoon when you have a heavy load on the batteries (air conditioning?), go around and measure the AC current into each battery with the Snapon (and you could check the current out as well, but they better be the same--law of physics and all). Write them all down and let's see what the largest and smallest is.
The impedances everywhere in your bank are in the order of milliohms (batteries themselves, cabling, connectors, etc.). Any differences on the order of milliohms can lead to large differences in ripple current in the batteries.
I'll be back from lunch in a while. :smile:
A/C amperage ranges from .8 to 1.5 amps throughout the bank.
D/C amperage is around 8 amps throughout the bank with the exception of one pair of batteries that is measuring around 25 amps charging. This is also the same pair of batteries that I got the zero amps read on at the common posts between the two batteries that I mentioned in an earlier post, that I decided must have been a poor connection which had caused the faulty reading. But this pair of batteries I expect is failing, at least the one that is connected to + in the parallel array, and it's the one with the damp top I had the picture of.
So at this time for some reason it is getting far more charge than the rest of the bank, and since there is one more negative plate than positive, the positive plate inside it is likely getting more cooked than the negative plate. As well, the positives are a paste in a bag, right? (Is this true for flooded cell?) And the negatives are solid lead.
So my bet at this point will be that if this battery fails (the one connected to + wire of the parallel array) that the other will be way undercharged when I separate the two. That's the MO I have described before.
That sure sound reasonable and safe. Is that with heavy load on the inverter ?
If your inverter is imposing ripple on the bank it'll be in proportion to load and at inverter's switching frequency.
Looks to me like you're making progress .
Difficult troubleshooting proceeds 'One tiny step at a time.'
Black silhouette clip art of a cartoon figure in a crouched, mid-stride pose, with arms outstretched and a large round shape at the feet.
Keep on truckin' .
old jim
So you have a 2 to 1 variation in the ripple current around your bank.
If it were me, the next thing I would do is measure the internal AC impedance of each 12 volt battery. This isn't too hard to do.
It would be good if you had more than 2 digits for your current reading. Is the Snapon clamp meter auto-ranging, or is 100-0-100 its only range? I'm sure that if the Snapon doesn't have a lower range, you probably have another clamp on with a low AC amp range.
So what you do is this. Have a handheld DMM set to AC volts range. Use test leads with sharp points on the DMM.
Clamp the clamp-on AC ammeter around the cable in the middle of a 24 volt pair; that's the cable that connects the two 12 volt batteries together. Poke the sharp tips of the probes on the DMM (set to AC volts) into the lead battery posts of one of the 12 volt batteries of the pair (do this same procedure to the other battery of the pair next. You don't have to move the clamp ammeter; it can stay clamped on that cable between the two batteries for the measurement on each battery because the ripple current in the two batteries is the same). Write down the AC ripple voltage measured by the DMM and the ripple current measured by the clamp ammeter. Divide the AC ripple voltage by the AC ripple current--that's the internal AC impedance of the battery.
Do this for all your batteries. Generally speaking, high internal impedance is bad, low is good. This measurement may help you detect batteries likely to fail.
Let us know what results you get.
You must monitor each cell of each battery for equal voltage during equalisation charge.
Keep record of all cells individually. You can see over time if there is a pattern of which cells
fail. Check temperature of each cell too. Should be equal, if not cells will not receive the same
charge and wiil fail over time. This seems to be your problem.
I suggest you design a datalogger for the purpose. For the cost of a battery you get a nice system.
Damp Top = Lots of gas being generated causing bubbles = Hydrolysis of H2O = Happens during overcharging
  1. Since it is one battery in a battery bank it's a battery problem, not a charging problem. (Yeah, we already knew that.)
  2. Why so much current? Not charged? No, that's not it because it's outgassing.
  3. Why so much current? Because one (or more) cell is shorted, reducing battery voltage.
  4. With less battery voltage bucking the charging voltage, the Volts per Cell goes up in the rest of the series cells, causing higher charge current = Overcharge of remaining cells = Outgassing = Damp top.
Two tests to verify: (use both)
(A)
Measure the voltage of each battery in the string that is charging at 25A while they are charging.
I expect the 'good' one to read a higher voltage than the 'bad' (wet?) one.
(B)
Disconnect that battery string (pair) from the bank.
If you have a battery load tester, use it here. If not, you can use an ordinary old fashioned car headlight as a load, high beam is about 3Amps.
Measure and record the voltage of each of the two batteries under load.
Leave disconnected for at least 24Hrs and measure their voltages again, under load.
The 'bad' battery will have a noticeably lower voltage after 24Hrs.
Might as well replace both of the series batteries at the same time. The second one, too, was severely overcharged and is about ready to fail. If you just replace one battery the older one will soon fail, taking the new one with it.
I once tried to measure a car battery's per cell voltage by connecting my voltmeter negative to battery negative then dipping the positive probe tip into each cell's electrolyte . I was looking for an open cell and figured with the engine running the open cell would show higher delta-voltage . I thought perhaps it was a broken intercell connector...
That battery was so weak it was inconclusive, each cell showed close to same increment . So i figured it probably had to be something else.Well duhhhh, the alternator belt was so loose that it was slipping and alternator couldn't keep up with electrical load of the airconditioner fan and clutch.
Anyhow - that imprecise and desperate test might find a shorted cell. You can work from either battery post.
old jim
Example: Some true RMS meters won't measure AC in presence of DC beyond voltage (or current--added by The Electrician) range selected - ie don't try to measure millivolts of AC riding atop ten volts of DC.
This is a very good point, Jim. What I do to check this is to change to a higher range on the DMM and see if the reading remains the same. The higher range will lose a digit of resolution, but when the reading is wildly different beyond just the loss of a least significant digit, you've got a problem!
So, BernieM, occasionally while you're measuring AC ripple current, change to DC mode and see if the DC current is much larger than the AC current. Change the range of the AC mode to a higher range and see if you get essentially the same reading. Of course, if your meter is autoranging, it may be impossible to force it to a higher range, although some autoranging meters do allow this.
Also, use a different clamp ammeter and compare readings to increase your confidence that you're not getting bogus measurements.
(A)
(B)
I checked the cells and there is little or no water missing, so this wetness is caused by a small amount of battery acid, as it never ran down the sides or got the top literally wet, merely dampened the dust on it.
A) 13.99 for the one connected to the + terminal and 14.06 for the one connected to the - terminal.
B) I have a carbon pile load tester (I think it's carbon pile anyhow.) I already did this test a week ago when I initially was discussing it here, and after a day (or was it two?) being disconnected the voltages were 12.6 and 12.6. Same. So if it hasn't failed yet. But I do believe it is in the process.
I did most of this in an earlier post (#57) where I actually answered some of these questions there.
old jim
I'm not sure but I think introducing a probe into a cell would create a new plate and a new battery, as well a different potential due to it being different metal (unless you used a lead probe...) which might be the reason for all the readings being about the same. I think you were measuring the potential of the probe in the electrolyte, so if there was a difference it was probably related to the strength of the electrolyte in the cells? Just a random guess.
