Designing a Solenoid: Equations and Force Calculations
  • Thread starter Thread starter ElectroPhysics
    Design Solenoid
To design a solenoid for operating a gas valve, it is essential to consider the permeability of the soft metal used for winding. Key equations for solenoid design include those for magnetic field strength and force calculations. Resources such as application notes and websites can provide valuable information on these equations and design considerations. Two recommended sites for further guidance are ledex.com and cliftronics.com. Accessing these resources will aid in effectively designing the solenoid and calculating the necessary operational force.
ElectroPhysics
I have to design a solenoid. It should be wound on some soft metal of certain permeability. It should have hollow inner dia that will be used to operate a gas valve. The problem is which equations should I use to design the solenoid. I also have to calculate the force that will be required for its operation. If someone knows the web address that have all these informations or some application notes is most welcome.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
