Solid disk rolling up a hill problem
The discussion revolves around a physics problem involving a solid disk rolling up a hill. Participants are trying to apply the conservation of energy principle, accounting for both translational and rotational kinetic energy, as well as potential energy. Confusion arises regarding the correct calculation of final speeds and the relationship between translational and angular velocities. Key points include the need to express final kinetic energies in terms of the unknown speed and the importance of using the moment of inertia for accurate calculations. Ultimately, the correct approach leads to finding the translational and rotational speeds of the disk after it rolls up the hill.
FlipStyle1308
I'm somewhat clueless on how to solve the following problem, since a solid disk is rolling up a hill rather than downhill.
A solid disk (mass = 5 kg, R = 0.6m) is rolling across a table with a translational speed of 6 m/s. The disk then rolls up a hill of height 2 m, where the ground again levels out. Find the translational and rotational speeds now.
I tried using KEi + PEi = KEf + PEf, including both KEt and KEr in KEf, and I calculated that KEi = 135J (45J are KEr, and 90J are KEt). I'm not sure if I'm plugging in my values correctly, since I got a translational speed of 3.847, and my answer was wrong.
You included gravitational potential energy and translational kinetic energy, but what are you forgetting?
Rotational kinetic energy? I thought I included that too...KEr.
Oh well then you should be getting the right answer. You probably have a mistake in your arithmetic.
I also got 135J for the total initial kinetic energy but I got a different answer for the final speed.
Okay...can you check my work?
I used KEi + PEi = KEr + KEt + PEf, which I used 135 + 0 = 45 + (0.5)(5)(v^2) + (5)(9.8)(2), and solved from there. Am I using these values incorrectly?
You have the wrong final rotational kinetic energy. The disk is still rolling when it's at the top of the hill but the angular velocity is not the same as it was before. (If the translational speed is now v, what's the angular speed?)
How would I go about correcting my KEr, and what would the fact that it's still rolling at the top of the hill change in my equation?
You would write your final translational kinetic energy in the same manner you wrote your final translational kinetic energy.
If the object has a translational speed of v then what is it's rotational kinetic energy? You already said that the translational kinetic energy would be \frac{1}{2}(5)(v^2) so now write the final rotational kinetic energy in terms of v.
Do you mean I should write my final rotational kinetic energy in the same way? Sorry, I am getting lost, since your previous 2 posts seem to be about 2 different things wrong with the problem. Would you be able to clarify what you are referring to?
You said 135 + 0 = 45 + (0.5)(5)(v^2) + (5)(9.8)(2).
Here you are assuming that the final kinetic rotational energy is the same as the initial kinetic rotational energy (45J).
I'm saying that that's not the case because the object is now traveling at at a speed v.
You wrote conservation of energy:
KEroti+KEtransi+PEi=KErotf+KEtransf+PEf
You then calculated the initial energies to be 135J:
135J=KErotf+KEtransf+PEf
Now you just need to write the kinetic energies in terms of an unknown speed "v" and then solve for v
Oh, okay. So I would ahve 2 unknowns in this problem? How would I solve each one?
Well you would have angular velocity and translational velocity. What is the relationship between the two?
v=rw? How would I incorporate that into the problem? I just simpliefied my equation and got 37 = 1.25w^2 + 2v^2
Well I don't know if you simplified your equation right or not but you know what w is in terms of v from the equation you just posted...
LOL I just figured that out...so w = 4.148, and then I plug that into v=rw to get v, which is 2.4888? Eek...these answers are wrong! Did I do something wrong?
Well since youre solving for v it would just be easier to substitute v/.6 for w in your final rotational energy.
I think you're just coming across arithmetic errors at this point.
I got the same answer...can you check if my work is wrong? I'm using:
37 = 1.25(v/0.6)^2 + 2.5v^2, which becomes 37 = 3.472v^2 + 2.5v^2, then 37 = 5.972v^2, 6.195 = v^2, then v = 2.489.
I think you divided by .62 before you plugged in v/.6 for w because I am getting 37 = 1.25(v)^2 + 2.5v^2
I had that 1.25 before I even divided by 0.6. I'm really confused now. Would you be able to show me your work for this problem?
135=\frac{1}{2}(9.8)(2)+\frac{1}{2}(5)v^2+.5(.9)(\omega)^2
37=\frac{1}{2}(5)v^2+.5(.9)(\frac{v}{.6})^2
37=2.5v^2+1.25v^2
Where did you get the .9?
That is the moment of inertia that I calculated for the disc.
I=.5mr^2 for a solid disc, axis through center
=.5(5)(.6)^2
=.9 kg-m2
Is inertia involved in this problem? I thought I was working with kinetic and potential energy only?
Show me how you solved for the initial rotational kinetic energy. You had to have used the moment of inertia.
The rotational kinetic energy is equal to \frac{1}{2}I\omega^2 where I is the moment of inertia and \omega is the angular velocity. You obviously used this formula when you calculated the initial rotational kinetic energy
Oh okay, I figured out that inertia part! I realized I used mass instead of inertia in KEr on accident! So Is my velocity if 3.14 m/s correct? And that gives me an angular velocity of 5.23?
That's the answer I got. Is that what the book gives?
Yes, thank you SO MUCH for all your help! I really appreciate all of this!
You're welcome. Sorry for the initial confusion.
Just remember that KE_{rot}=\frac{1}{2}I\omega^2 and v=r\omega.
Just for future reference you have to be careful because the relationship v=r\omega assumes the object is not slipping.
Oh okay. What I really didn't understand about this problem that confused me is the fact that the disk was rolling up a hill. I still cannot picture that happening on its own lol.
