How Do You Calculate the Radii for Washers in Solids of Revolution?
  • Thread starter Thread starter nameVoid
    Revolution Solids
nameVoid
y=x^2 ;
y=4;
rotated around x=2
im seeing a washer cross section with r=2-y^(1/2);
im unclear on how to get R to calculate the area it seems to be 2r but this produces incorrect results.
y=x^2 is a parabola and y=4 is a line. Rotate these about the x=2 axis and the object is a paraboloid.
im clear on the shape of the solid , but how do you get an equation for the large radius of the washer
When you rotate the region of the parabola y = x^2 around the line x = 2, the vertical cross-section of this solid looks like two parabolic sections. The part on the right has its vertex at (4, 0) and intersects the line y = 4 at (2, 4) and (6, 4). The equation of this translated parabola is y = (x - 4)^2.
The large radius of a washer is the x-value on the parabola on the right, minus 2, or sqrt(y) + 4 - 2. You can also get this dimension by taking the x value on the parabola on the left, and you'll get the same value.
You mentioned that you had calculated the large radius as 2 - sqrt(y). That actually gets you the inner radius. Using the parabolic region on the right, I get an inner radius of 4 - sqrt(y) - 2, which is what you had for the outer radius.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
