Solution to an initial value problem
dooogle
dy/dx=5y(1-y)
y(0)=0.1
x belongs to [0; 2]
dy/5y(1-y)=dx
using partial fractions (1/(-y^2+y))=1/(y(1-y))= A/y+B/1-y
multiplying both sides by (y(1-y)) gives 1=A(1-y)+B(y)
when y=0 1=A so A=1
when y=1 1=B so B=1
so 1/(1-y) +1/y =1/(y(1-y))
1/5*(int 1/(1-y)+int 1/(y))=1/5*(-ln (1-y)+ln (y))
so x=1/5*(-ln (1-y)+ln (y))
5x=-ln (1-y)+ln (y)
e^5x=y/1-y
but that doesn't work when y(0)=0.1 does y(0)=0.1 mean when y=0 or when x=0? either way i don't get the right answer please can someone explain where I am going wrong
cheers
dooogle
5x=-ln (1-y)+ln (y)
e^5x=y/1-y
You forgot about the integration constant. The initial value y(x=0)=0.1 will fix the value of the integration constant.
so e^5x +c =y/1-y where c=0.1
is a gd answer?
im just concerned due to the fact i have 2 y's thanks for the help
dooogle
No, the integration constant came in as
5x + C =-ln (1-y)+ln (y)
So you'd have
e^{5x + C} = \frac{y}{1-y} .
This is not the simplest form of the equation. We can still solve for y directly.
e^-(5x+c)=(1-y)/y
e^-(5x+c)=(1/y)-(y/y)
e^-(5x+c)=(1/y)-(1)
e^(5x+c)=y-1
e^(5x+c)+1=y?
dooogle said:
e^-(5x+c)=(1/y)-(1)
e^(5x+c)=y-1
The 2nd line does not follow from the first.
\frac{1}{\frac{1}{y} -1} \neq y -1
Try writing 1/y by itself on one side of the equation:
\frac{1}{y} = ?
Then you can compute the reciprocal of both sides to determine y.
e^-(5x+c)=(1/y)-(1)
raise both sides to the power of minus 1 so 1/y=y^-1 becomes y and -1 becomes -1^-1 =1/-1 =-1 and e^-(5x+c)=1/e^(5x+c) becomes e^(5x+c)
e^(5x+c)=y-1
dooogle said:
e^-(5x+c)=(1/y)-(1)
e^(5x+c)=y-1
No, it doesn't work that way
\frac{1}{a+b} \neq \frac{1}{a} + \frac{1}{b}.
Use my suggestion by adding 1 to both sides of
e^-(5x+c)=(1/y)-(1)
Compare the answer you get with the wrong result.
ok i understand now thanks for your help
i did what u said
e^-(5x+c)=(1/y)-(1)
1/y=e^-(5x+c) +1
y=1/(e^-(5x+c) +1)
thanks very much for help
doogle
No problem. Don't forget to use the initial condition to eliminate the integration constant.
