Solve Chem Word Problem: 16 mL 5% Eye Drops
The discussion revolves around a chemistry homework problem involving the preparation of a 5% active ingredient eye drop solution using available 10% and 1% solutions. The goal is to determine the volumes of each solution needed to create 16 milliliters of the desired concentration. A user suggests setting up an equation, where x represents the volume of the 10% solution and (16 - x) represents the volume of the 1% solution. The equation to solve is based on the total amount of active ingredient in the final mixture, leading to the formulation 0.05(16) = 0.10x + 0.01(16 - x). The discussion emphasizes solving the problem using a mathematical approach rather than a purely chemical one, highlighting the importance of setting up the correct equations to find the solution volumes.
Zed
chem word problem ! please help
Hi ,
This is a Hw question i have am stuck on i don't know how to solve it ...
A pharmacist is to prepare 16 milliliters of special eye drops for a glaucoma patient. The eye-drop solution must have a 5% active ingredient, but the pharmacist only has 10% solution and 1% solution in stock.
How much of 10% solution should be used to fill the prescription?
How much of 1% solution should be used to fill the prescription?
please help
thx
Chemistry news on Phys.org
Borek said:
For theory:
http://www.chembuddy.com/?left=concentration&right=dilution-mixing
As the densities are not known, assume them to be 1 g/mL.
For fast calculations - try CASC (concentration calculator).
Borek
Chemical calculators at www.chembuddy.com
pH calculation
concentration conversion
thanks for ur reply... but i should solve this as a math word prolem not as a chemistry problem .. i mean an equation of the form : 0.03x + 0.10(16-x)= ...
Assume the pharmacist uses x ml of 10% solution and 16 - x ml of 1% solution. Compare the total volume of active ingredient with the required number and solve for x.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
