Solve Columb's Law Problem: q1 for q2=4.4nC, Dist 10cm and 20cm
  • Thread starter Thread starter jfusion
    Law
The problem involves calculating the charge q1 given q2 is 4.4nC, with distances of 10cm and 20cm between the charges. The equilibrium condition is expressed through the equation F=k*q1*q2/(2d)^2 + k*q*q2/d^2 = 0. Initial calculations yielded an incorrect result of 1.7x10^-8 C, prompting discussions on rounding, significant figures, and the sign of the charge. Ultimately, the correct answer for q1 was determined to be 16nC. The resolution highlights the importance of charge sign and accurate unit conversion in electrostatic calculations.
jfusion
Charge q2 in the figure(Figure 1) is in static equilibrium. Assume that q = 4.4nC .
Figure:http://session.masteringphysics.com/myct/itemView?assignmentProblemID=31833513&offset=prev
what is q1 ( distance between q2 and q is 10com and distance between q1 and q2 is 20cm)
I then isolate for q1
My answer is 1.7x10^-8 C which is wrong, I have converted all givens to Standard units
We don't have access to the figure since we can't log into the publisher's site.
Thanks for pointing that out, here's the image
Maybe it's just a matter of rounding or sig figs.
i don't believe so, do you come to the same conclusion?
Yes, but when I round to two sig figs, I get a slightly different answer. Also, it could be that you didn't specify the correct sign of the charge.
what do get as your final answer? and the charge would be + correct?
it accepted 16nC thanks for the help
10K
10K
11K
