Solve Efficiency Problem: Heat Water in 1000 W Electric Kettle
  • Thread starter Thread starter physicsnerd7
    Efficiency
The discussion revolves around calculating the time required for a 1000 W electric kettle to heat 1.0 L of water from 10 °C to boiling point, considering the kettle's efficiency of 63% and the mass of the kettle itself, which is made of iron.
  • Mixed
  • Participants explore the calculation of effective power used to heat the water and the need to include the energy required to heat the kettle itself. There are discussions about the implications of the kettle's efficiency and how it affects the overall energy transfer.
Some participants have provided guidance on incorporating the kettle's mass into the energy calculations. There are differing views on the relevance of the kettle's material and efficiency, with some suggesting that the original poster's initial calculation could be justified based on the given efficiency.
There are concerns about the clarity of the problem statement, particularly regarding the efficiency figure and its application to the energy transfer between the kettle and the water. Participants question the assumptions made about the energy distribution and the role of the kettle's material in the heating process.
physicsnerd7
Determine the amount of time it will take a 1000 W electric kettle to heat up 1.0 L of water to boiling point if the water starts at 10 °C and the kettle is made from 400 g of iron. The transfer of heat energy from the kettle to the water is 63%.
P = W/Δt
Q = mcΔT
Okay so what i was thinking was find 63% of the 1000 W electric kettle and then that is the power used to bring the water to a boil so I did -
Pfor water = 1000W x 0.63
= 630 W
then I would use this power in the formula P = W/Δt to find time so I did -
Δt = (mwater x cwater x (Tf of water - Ti of water) ) / 630 W
= (1kg x 4.2E3 J/kgC x (100 C - 10 C )) / 630 W
= 600s ||or|| 10 min
apparently this answer is wrong because I am suppose to incorporate the mass of the iron kettle but I don't know how. Please help!
You have the correct equation for the energy needed to heat the water mwater x cwater x (Tf of water - Ti of water). Write similar equation for the energy needed to heat the iron. What laws do you know about energy?
PS: I believe they are saying that the 63% figure applies between the kettle and the water not the element and the water.
Δt = (mwater x cwater x (Tf of water - Ti of water) + miron x ciron x(Tf iron - Ti iron)) / 630 W
Is ^ this correct then. I know that energy can't be created or destroyed and that it is only transferred from one form to another.
The more I think about this problem the more I think it's badly specified and your first answer based on 63% of 1000W could be justified.
I agree. Based on the masses and specific heats, you'd think 96% of the heat would go into the water (did I get that right?). If only 63% went that way then the rest has been radiated/convected away to the room. This leaves the OP calculation as the only route to the answer. The mass and composition of the kettle are irrelevant.
Okay so then the 600 s answer is right then because the only thing affecting the heating up of the water is the amount of power the kettle has and not what the kettle is made from. And since the kettle is only 63% efficient then only 630W is going towards heating the water.
35K
  • · Replies 18 ·
  • · Replies 20 ·
23K
36K
