Solve Energy Conservation Problem: 17 kg Child Descending 3.5m Slide
A physics problem involves a 17 kg child descending a 3.5 m slide, reaching a speed of 2.5 m/s, and requires calculating thermal energy generated due to friction. The relevant equation relates initial and final kinetic and potential energy, including friction. The distance traveled (d) was initially unclear, but it was determined that it is not necessary to find the thermal energy. The thermal energy due to friction was calculated to be approximately 530 J. The discussion highlights the importance of understanding energy conservation principles in solving such problems.
confusedbyphysics
Please help me, this is due tonight at 11 and I can't figure out what to do!
" A 17 kg child descends a slide 3.5 m high and reaches the bottom with a speed of 2.5 m/s. How much thermal energy due to friction was generated in this process?"
The equation should be:
kinetic energy intiial + potential energy initial = ke (final) + pe (final) + friction X distance travelled
so
1/2mv^2 (initial) + mgy (initial) = 1/2mv^2 (final) + mgy(final) + Friction X d
The problem is I don't know d!
0 (no initial KE) + (9.8)(17)(3.5) = 1/2(17)(2.5)^2 + 0 (no final potential energy) + friction X d!
What is D!
I tried making the slide a right triangle with 45 degree angles for the other two and using the pythagorean theorem...and got 5 for the distance..but I got a wrong answer..
huh, could someone PLEASE help me!
You don't need D to find out the answer, one second ill post my toughts.
ok let's see... forgive me if I am wrong...
Change E system = Change E mechanical + Change E thermal
E thermal is the friction and its equal to friction force times delta S
Change in mechanical energy is Eo-Ef... so 0 = Eo-Ef + E thermal
so
-E thermal = Eo - Ef
- E thermal = PEo - KEf
E thermal = Kef-PEo
E thermal = -530.025 J
Alright i hope this helps and anyone correct me if I am wrong... thanks
Thanks. Hmm , my class hasn't learned how to do that yet. Is there any way to do it with the PE + KE = KE + PE + Fr (d)?
thats exactly what I am doing except I am not using the distance...
(PEo + KEo) - (PEf+KEf) = - Work Friction (which is equal to Fr (d) ) Oo
if you need to do further work with the friction you can use the result i got and do
Work friction = Force friction (d)
:X
Doh! You are right, seiya, the answer is 530. The friction work is Friction X d. For some reason I thought I was just looking for the force of friction. Stupid me.
Thank you for the help! :)
you are welcome , just helping while thinking about my problem and hoping someone will give me a hint :p
