Solve f(x) = ce^-x, Find E(x) and Probability Generating Function
The discussion revolves around the function f(x) = ce^-x for x = 1, 2, 3..., focusing on finding the constant c, the moment generating function, the expected value E(x), and the probability generating function. Participants are examining the correctness of provided answers and seeking assistance with the calculations involved.
  • Participants are attempting to determine the value of c by setting up an equation involving a geometric series. There is confusion regarding the correct expression for c, with one participant questioning the relationship between e and the derived value. Others are discussing the moment generating function and how to proceed with the calculations, including substitution in summations.
The discussion is active, with participants clarifying their understanding of the first question about finding c. Some guidance has been provided regarding the geometric series involved in the calculations. However, there is still uncertainty about the moment generating function and how to continue from a partially completed solution.
Participants are required to show their work according to forum rules, which may influence their approach to solving the problem. There is mention of a discrepancy between the book's answer and the participants' findings, indicating potential confusion or misinterpretation of the problem setup.
JoanneTan
Here is the question,
f(x) = ce^-x , x = 1, 2, 3...
Find the value of c.
Find the moment generating function of X.
Use the result obtained, find E(x).
Find the probability generating function of X.
Verify that E(x) obtained using probability generating function is same as the first E(x) founded.
I check the answer of the book, but it's wrong. Can someone help me? I'm looking for the working.
PF rules require that you show your work.
Ok.. For the first question which is to find value of c.
But the answer given is e - 1.
It's not e^-1.. I'm confusing how to get e - 1.
Yes, you must have [itex]ce^{-1}+ ce^{-2}+ ce^{-3}+ \cdot\cdot\cdot= 1[/itex]
You can factor out [itex]ce^{-1}[/itex] and have [itex]ce^{-1}(1+ e^{-1}+ e^{-2}+ \cdot\cdot\cdot)[/itex]
That is, as you say, a geometric series with common factor [itex]e^{-1}[/itex] so is equal to [itex]\frac{ce^{-1}}{1- e^{-1}}= 1[/itex]. That, you have. Now multiply both numerator and denominator by [itex]e[/itex]:
[itex]\frac{c}{e- 1}= 1[/itex].
Oh! Ok.. I get u now.. Thanks a lot! But the second question, moment generating function,
As u can see from the photo, I done until half, can help me to continue? Cause dono how to substitute.
You need to calculate the sum [tex]\sum_{n=1}^{\infty} e^{-n} e^{kn}<br /> = \sum_{n=1}^{\infty} r^n, \text{ where } r = e^{k-1}[/tex]
You have already seen how to do such summations; look at part (a)!
  • · Replies 19 ·
