Solve for Post-Collision Masses: Conservation of Momentum
  • Thread starter Thread starter jmill5504
The discussion focuses on solving a physics problem involving two colliding masses, m1 and m2, which stick together after the collision. Participants emphasize using the conservation of momentum principle, stating that the total momentum before the collision equals the total momentum after. The final momentum in both x and y directions must be calculated to find the final speed and direction of the combined mass. The importance of clearly stating the question in the thread title is also highlighted to aid in receiving relevant assistance. Understanding the conservation of momentum is crucial for solving such collision problems effectively.
jmill5504
two masses are initially moving as follows: m1= 10.0 kg with a v1i = (0 m/s, 10 m/s), and m2= 5.00 kg with a v2i= (10 m/s, 0 m/s) THey collide and stick together, forming a composite mass of 15.0 kg. Use the principle of momentum conservation to find the magnitude (vf) and the direction of motion of the combined masses after the collisio.
that is the ? and i don't know where to begin at all someone help me please
You have two masses moving in a plane. The masses collide and stick together. The question asks you to determine the speed of the composite object after the collision and its direction of motion. The problem tells you to use conservation of momentum, so what does conservation of momentum say?
Momentum is conserved in any collision if the effect of any external forces present is negliable relative to the effect of the collision
find the final momentum in the x and y directions.they must be equal to the initial momentum.
final momentum in x direction = M* v(x) = m1*v1(x) + m2*v2(x)
final momentum in y direction = M* v(y) = m1*v1(y) + m2*v2(y)
u know M=m1+m2, m1,m2 and v1 and v2.
find v(x) and v(y).
That is a description of the conditions under which conservation of momentum applies. It is not a description of the actual principle of conservation of momentum.
Conservation of momentum means that the total momentum of the two objects before the collision equals the total momentum of the two objects after the collision.
By the way, on a completely different subject, it really helps people here a lot if you put something in your thread's subject line that indicates what your question is about. For example, you could have used "Conservation of momentum problem".
