Solve Ka for Weak Acid HCN - 0.18mol KCN in 1.00L, pH 9.70, 298K
  • Thread starter Thread starter Aly
    Acids Weak
To calculate the Ka for the weak acid HCN from the given data, start by determining the Kb using the equilibrium concentrations. The pH of 9.70 allows for the calculation of pOH and the hydroxide ion concentration [OH-]. With the equilibrium concentration of CN- at 0.13M, use the Kb expression to find the concentration of HCN. Finally, apply the relationship between Ka and Kb to derive Ka for HCN. This approach utilizes the Henderson-Hasselbalch equation for accurate results.
Aly
hi forum,
would nebody be able to help me solve this problem?
0.18mol of potassium cyanide (KCN) was dissolved in 1.00L of a solution in which the pH was held constant at 9.70 at a temperature of 298K.
the equilibrium concentration of CN- was 0.13M.
Calculate Ka for the weak acid HCN.
ne help would be greatly appreciated. :)
Chemistry news on Phys.org
Use Henderson-Hassebalch equation. It won't be difficult to calculate equilibrium concentrations of HCN and CN- - just enter them into HH and solve for pKa.
hi forum,
Start with finding Kb
Kb= \frac{[OH-][HCN]}{[CN-]}
You can find the initial concentration, you also know the equilibrium concentration, thus you can find how much of CN- reacted. It also says that the pH was held constant. From the pH given, find the pOH, from this calculate the concentration of hydroxide [OH-]. This is the equilibrium concentration thus you can plug it back into the equilibrium equation.
How would you find the HCN concentration to solve for Kb...and then Ka?
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
