Solve Maclaurin Expansion Equation: cos(x)-2x2=0
pat666
Use the first two terms of the Maclaurin series expansion of cos(x) to solve the equation cos(x)-2x2=0 . Check its accuracy with a calculator ( is in radians).
f(x)=f(0)+x(f'(0)) first two terms
So I have found the Maclaurin expansion of cos(x) to be 1. This seems ridiculous to me so I'm wondering if its correct?
then:
1-2x2=0 so x=+-(sqrt(2)/2)
=+-.239755
I'm not sure what to say about the accuracy??
FYI this is an exam practice Q
Thanks
You want the first two non-vanishing terms. Go to higher order in the expansion.
ok, non vanishing means not 0?
now I get cos(x)=1-x^2/2
and the solution is +-0.816497
the actual answer is +-.63456 - seems reasonably accurate?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
