Solve Mechanics Problems: Find Time & Displacement Relation
  • Thread starter Thread starter AhmedHesham
    Mechanics
The discussion revolves around solving two mechanics problems involving force, displacement, and velocity. The first equation, F=m(x+2), relates displacement to time, while the second, F=m(2v+3), focuses on finding velocity as a function of time. Participants suggest using differential equations and exponential trial solutions to derive the relationships. Initial conditions are provided for both equations, with guidance on integrating to find the necessary relations. The conversation emphasizes the importance of showing effort in problem-solving and integrating the equations correctly.
AhmedHesham
A problem I can't solve
F=m(x+2)
F=m(2v+3)
First
F=m(x+2)
Initial velocity is 2m/s
find the relation between the time and displacement
Second
F=m(2v+3)
Initial velocity is 3 m/s
Find v(t)
Please help me
I tried but I can't finish it
AhmedHesham said:
Problem Statement: A problem I can't solve
Relevant Equations: F=m(x+2)
F=m(2v+3)
First
F=m(x+2)
Second
F=m(2v+3)
Find v(t)
Please help me
What have you done so far?
Likes AhmedHesham
first I applied a=vdv/dx
and in the second one
I applied a=dv/dt
Substitute an exponential trial solution
##A+Be^{Ct}##
(either as displacement or velocity) in the differential equation and try to determine what A,B,C should be for the equation to be correct.
##A+Be^{Ct}##
How can I solve it with simple calculus
You need to start showing more effort here, or this thread will be closed. Please use the hint given by @hilbert2
The first equation is a differential equation for the displacement ##x(t)##,
##m\frac{d^2 x(t)}{dt^2} = m(x(t)+2)##
and the second one a DE for the velocity ##v(t)## (it could also be written for displacement, but it's not what is asked here),
##m\frac{dv(t)}{dt} = m(2v(t)+3)##.
The initial condition in the first is ##x(0)=2##, and in the second ##v(0)=3##. The parameters in the equations are dimensionless, so I won't add units to these initial conditions, either.
If you put the exponential trial function in the place of ##x(t)## or ##v(t)## in either equation, you will get an equation that you can try to change into an identically true statement by adjusting ##A,B,C##.
Sorry if I gave too much information compared to the poster's own effort.
thanks
I applied a=dv/dt
This was a good idea. So, in the first one, $$mv\frac{dv}{dx}=m(x+2)$$and$$vdv=(x+2)dx$$
Do you know how to integrate this?
Yes
And I will have a relation between vsquard and x
What next
AhmedHesham said:
Yes
What next
Let’s see what you got.
