Solve Modeling Higher-Order Diff Eqn: Free Undamped Motion w/ Spring
The discussion focuses on solving a higher-order differential equation related to free undamped motion of a mass-spring system. The mass of 1 slug is suspended from a spring with a spring constant of 9 lb/ft, initially released from 1 foot above the equilibrium position with an upward velocity of √3 ft/s. The correct differential equation for the motion is identified as x(t) = -cos(3t) - (√3/3)sin(3t). The goal is to find the times when the mass is moving downward at a velocity of 3 ft/s, leading to a quadratic equation that can be solved for sin(3t) and subsequently for t.
  • Understanding of differential equations, specifically second-order linear equations.
  • Familiarity with concepts of simple harmonic motion.
  • Knowledge of trigonometric identities and their applications in solving equations.
  • Ability to manipulate and solve quadratic equations.
  • Study the derivation and application of the general solution for second-order differential equations.
  • Learn about simple harmonic motion and its mathematical representation.
  • Explore trigonometric identities that simplify solving equations involving sine and cosine.
  • Practice solving quadratic equations derived from trigonometric functions.
Students and professionals in physics, engineering, and mathematics who are dealing with differential equations and motion analysis in mechanical systems.
Matthewmccoy6
A mass of 1 slug is suspended from a spring whose spring constant is 9lb/ft. The mass is initially released from a point 1 foot above the equilibrium position with an upward velocity of square root 3 ft/s. Find the times at which the mass is heading downward at a velocity of 3 ft/s.
I found the differential equation to be x(t)=Acos(3t) + Bsin(3t).
What I did was I took downward as positive while upward as negative. I'm having trouble finding t.
My equation for the motion was x(t)= -cos 3t - (square root 3/ 3) sin 3t
Please help, thanks!
That is NOT a differential equation. I presume you mean you found that as the general solution to the differential equation.
So you need to solve
[tex]-cos(3t)- (\sqrt{3}/3)sin(3t)= 3[/tex].
That is the same as
[tex]cos(3t)= 3- (\sqrt{3}/3)sin(3t)[/tex]
Squaring both sides of that gives
[tex]cos^2(3t)= 9- (2\sqrt{3}/3)sin(3t)+ sin^2(3t)[/tex]
Replace [itex]cos^2(3t)[/itex] with [itex]1- sin^2(3t)[/itex] and you have
[tex]1- sin^2(3t)= 9- (2\sqrt{3}/3)sin(3t)+ sin^2(3t)[/tex]
a quadratic equation you can solve for sin(3t) and then for t.
Be sure to check if an "extraneous" solutions were introduced by the squaring.
I know, this is a differential equation problem though and using the equation of simple harmonic motion I found the above equation.
Also, I was hoping there was a simple identity that I could use to find t rather than something really unpleasant. Thanks though.
  • · Replies 22 ·
