Solve rpm in rotational motion problem
To determine the required rpm for a centrifuge to achieve an acceleration of 100,000 g's at a radius of 7.0 cm, the radial acceleration formula was applied. The calculations initially yielded a result of 3,741 radians per minute. However, this value needed conversion to rpm, which involves multiplying by 60 and dividing by 2π. The final answer, after conversion, approximates to 36,000 rpm, aligning with the textbook's answer of 3.6x10^4 rpm. The discussion emphasizes the importance of unit conversion in rotational motion problems.
adca14
How fast (in rpm) must a centrifuge rotate if a particle 7.0 cm from the axis of rotation is to experience an acceleration of 100,000 g's?
My variables
radius= 7 cm or .07m
radial accel= 100,000 g's or 980,000m/s^2 or 98,000,000cm/s^2
V= I think I need this to get w
w= ? I think I need to solve this to get rpm
rpm= ? this is what I want
radial accel = v^2/r
v= rw
980000/.07 = 68,600
\sqrt{}68600/.07= 261.9
261.9/.07 = 3,741 rpm
whether i set everything as meter or centimeter, I still get the same answer. I check the back of the book and it says 3.6x10^4 or 36,000rpm
Any help would be appreciated.
Your answer is correct but it's in radians per second. rpm is revolutions per minute. A revolution is 2*pi radians and a minute is 60 seconds. Can you convert it to rpm?
thank you, I did:
3741rad*60=224,460
224,460/2*pi=35,723rpm or 36000rpm if I round up. Thanks again!
