Solve Simple Diode Problem: Voltage Drop @ 300K
  • Thread starter Thread starter Qbit42
    Diode
The discussion revolves around a problem involving a series circuit with a diode, a resistor, and a DC power supply. Participants are tasked with calculating the voltage drop across the diode at a temperature of 300 K, given specific current and saturation current values.
  • Mixed
  • Participants explore the diode equation and its rearrangement to find the voltage drop. There are discussions about potential errors in the original equation and the significance of the saturation current value. Some participants suggest checking the number of significant figures and the inclusion of an ideality factor in the diode equation.
Several participants have attempted to clarify the problem and share their experiences with similar calculations. There is a recognition of potential issues with the problem setup, but no consensus has been reached on a definitive solution. Some guidance has been offered regarding the calculation process and the interpretation of the problem statement.
Participants note that the problem is part of an online assignment with strict answer requirements, which may not accept certain approximations or interpretations. There is also mention of a second part to the problem that involves the resistor's value, which has not been fully addressed in the initial discussion.
Qbit42
You have a series circuit consisting of a dc power supply, a 90 ohm resistor and a diode.
If the measured current in the circuit is 136 mA, and the saturation current for the diode is 0.006 mA, what is the voltage drop across the diode? Assume the diode temperature is 300 K. Your answer should be given to three places after the decimal point.
I = I_{o}(e^{\frac{qV}{k_{b}T}}-1)
q = 1.602x10^{-19}
k_{b} = 1.38x10^{-23}
Rearranging the above the equation I get
\frac{k_{b}T}{q}ln(\frac{I}{I_{o}} + 1) = V
Plugging in the numbers I get 0.259V which isn't the right answer, I know this problem isn't difficult but I can't seem to wrap my head around why this doesn't work.
I = I_{o} e^{\frac{qV}{k_{b}T}}-1
q = 1.602x10^{-19}
I believe you are missing a pair of parenthesis in your first equation...
Oh yeah I missed that, fixed it in the post above
So does that fix your answer?
no I formulated my equation from the correct expression, I just mistyped it in the original post
Your result is correct.
ehild
Well that sucks, the problem is in an online assignment and it only accepts the right answer (we get 3 tries at it). It won't accept that one.
Interesting that it gives the resistance of a series resistor and does not use its value in the question. Maybe, they wanted to ask the emf of the source.
ehild
ehild
Well there is a second part to this problem where the resistance of the resistor is needed, I just didn't post it since it had no bearing on this part of the problem. Here it is:
What is the voltage across the diode-resistor combination?
I have a few ideas about what might be wrong.
1. 0.006 mA seems pretty large for a diode saturation current. I think nA or pA range is more reasonable. Do they really say 0.006 mA, or could it have been 0.006 μA? Or something else?
2. Perhaps there are too many significant figures in the answer "0.259 V". Try the calculation using saturation currents of 0.0055 and 0.0065 mA, to get a sense of how many sig figs are justified.
3. Shouldn't the diode equation include an extra material-dependent ideality factor in the qV/kT term? Perhaps they expect the student to know what it should be, so they didn't provide the value in the problem statement.
I just copied and pasted the problem directly from the problem set
It says it wants my answer within 3 numbers after the decimal point
I took that equation directly from our lab handout, this question is a for a prelab problem worth a small fraction of the lab mark, but I also found it mentioned in the textbook (however nothing really much was said about it)
Okay, sounds like those were three dead ends. Oh well, sorry.
thanks anyways, I guess I'll just have to forget about it.
You are doing it right, I had the same question but different values:
120 ohm resistor, current in the circuit (I) = 73mA, saturation current (Io) = 0.010mA, and T=300K.
My answer came out to be 0.230V which was accepted as correct. Just try it again and make sure all your calculations are correct.
I'm not sure how to get the second part:
Any ideas?
Any ideas?
Have you considered VD + VR ?
Ahh...yes. I had put in Vr-Vd.
Vd + Vr worked, I got 8.99V/
Thanks!
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 20 ·
