Solve Simple Series Sum: Find Sum or DNE
  • Thread starter Thread starter tangibleLime
    Series Sum
tangibleLime
Find the sum of the series, if it converges. Otherwise, enter DNE.
\Sigma = \frac{7}{n(n+2)}
The sigma is from n=2 to infinity.
I really don't know how to go about this problem. My professor has tenure and he's pretty much checked out at this point, and the book is a $100 paper weight.
I tried to get it to look like a geometric series by factoring the bottom into n^2+2n, pulling out the 7 and ending up with
7 \Sigma \frac{1}{n^{2}+2n}
But this looks wrong and I have no idea what to do. A push in the right direction would be great.
Well, first thing I'd do is check that it DOES converge. You can worry about finding a sum later. As for finding if it converges, either an integral test or a comparison test to 1/n^2 would work.
It's not geometric. Compare with a power series. What do you know about series of the form 1/n^p? Does the $100 paperweight have anything to say about them?
I'm going to assume that you have found out how to prove convergence. I'm also going to divide by 7.
To evaluate this sum, you're going to want to search for a pattern. Start by looking at the terms corresponding to n, n+2, n+4, ... . For consecutive terms of this form we have
1/n(n+2) + 1/(n+2)(n+4) = 2/n(n+4).
See if you can find the pattern; then apply your findings individually to the the terms for which n is even and those for which n is odd.
take 7 out of the sigma and write
1/n(n+2) = [1/n - 1/(n+2)]/2
Take 1/2 out too.
now find term 1, term 2, term 3 and you will see a pattern where many things get cancelled. Add the rest, and multiply by the 7/2.PS: I assume you know the convergence proof.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
