Solve the differential equation
chwala
solve the differential ##x(x+y)y^{'}=x^2+y^2## given initial conditions ##y=0, x=1##
differential equations
on introducing a term on both sides,
we have
##(x^2+xy-2xy)y^{'}=x^2+y^2-2xy##
##(x^2-xy)y^{'}=(x-y)^2##
##x(x-y)y^{'}=(x-y)^2##
##xy^{'}=(x-y)##
##y^{'}=1-y/x##
## v+x v^{'}=1-v## ...ok are the steps correct before i continue?
chwala said:
Homework Statement:: solve the differential ##x(x+y)y^{'}=x^2+y^2##
Homework Equations:: differential equations
we have
You have ##-2xyy'## added on the left and only ##-2xy## on the right.
##xy^{'}=(x-y)##
##y^{'}=1-y/x##
Should say "solve the differential equation..."
The substitution v = y/x will lead to a separable differential equation, assuming that I haven't made an error in the work I've done so far.
Keep in mind that v = y/x is equivalent to y = vx, so y' = v'x + vx' = v'x + v. Here y' means dy/dx and x' means dx/dx = 1.
yes, is that fine?
but that's what i did! ok, let me continue solving then you may countercheck me...
chwala said:
yes, is that fine?
No. You can't add different quantities to the two sides.
It's not at all obvious that this is what you did, plus, you started with an error on your first line.
If you use the substitution that I suggested, be sure to write something like "let v = y/x" so a reader can follow what you're doing. In your work, v and v' mysteriously appear, with no explanation of what they are, and since the preceding steps are incorrect, the substitution won't lead to a valid result.
##y^{'}=1-y/x##
## v+x v^{'}=1-v##
Likes chwala
##v+xv^{'}=1-v##
##xv^{'}=1-2v##
##\frac {dx} {x}= \frac {dv} {1-2v}##
letting ##u=1-2v## and integrating
## -\frac {1}{2} ln [1-2v]=ln x + ln k## where ##k## is a constant.
##-\frac {1}{2} ln [1-2v]=ln[xk]##
are the steps correct...
sorry, i assumed that you will know what i did...
The textbook answer is ##y=x ln \frac {x}{(x-y)^{2}}##
i am sorry i did not give the initial condition ## y(1)=0## that is ##y=0, x=1## i guess i am tired...time for the holidays...
i see:smile: implying my working is wrong, your input Fresh...guess am tired...
i need your input am stuck.
Let's start from the beginning.
We have ##x(x+y)y^{'}=x^2+y^2## and ##y(1)=0##.
Then @Mark44 gave you the hint to substitute ##v=\dfrac{y}{x}##.
Now ##v'= \dfrac{y'x-y}{x^2} = \dfrac{y'}{x}-\dfrac{y}{x}\cdot \dfrac{1}{x}## or ##v'x=y'-v##.
Which equation do you get, if you divide the given one by ##x^2## and express the result in terms of ##x,v,v'##? And is this substitution allowed in the domain we are interested in? Why?
Likes chwala
ok i have followed your steps and it's interesting, i hadn't seen it that way! i did not expect to start with ##v=yx##...
ok dividing the equation by ##x^2##
am getting,
##(1+v)y^{'}=1+v^2##
therefore,
##v+x \frac {dv}{dx}= \frac {1+v^2} {1+v}## correct?
Yes that's correct. I would also replace ##y'## by ##v'## and ##x## terms. You have now three variables (##x,y,v##), but we want only two (##x,v##). I haven't solved it yet, so I don't know the best way. But let's see what we get.
Likes chwala
Mark mentioned separation of the variables, too. (See post #3.) This means, we try to get all terms with an ##x## and one side and all terms with a ##v## on the other, preferably ##dx## and ##dv## in the numerators.
ok let me solve it, am now getting after simplification,
##\frac {1+v} {1−v}## dv= ##\frac {dx} {x}##
on integration i am getting;
##2ln(1−v)−(1−v)=lnx##
→ ##2ln(1−v)− ln x= (1-v)##
thanks to you and Mark (i've known him for quite sometime :wink:)...
##\frac {1+v} {1-v^2}## dv= ##\frac {dx} {x}##
I think this is wrong. I get from your ##v+ x\dfrac{dv}{dx}=\dfrac{1+v^2}{1+v}##
\dfrac{dx}{x} = \dfrac{1}{\dfrac{1+v^2}{1+v}-v} \,dv= \dfrac{1+v}{1+v^2-v(1+v)} \,dv = \cdots
and now you can integrate both sides.
Edit: I got the impression that you do too many steps in mind instead of writing them. To write is not only faster than to think, it helps to avoid mistakes, too.
fresh_42 said:
I think this is wrong. I get from your v+xdvdx=1+v21+vv+xdvdx=1+v21+v
fresh i do not see how my step is wrong...i took
##\frac {1+v^2} {1+v} - v##= ##\frac {1+v^2-v-v^2} {1+v}##= ##\frac {1-v}{1+v}##
chwala said:
i took, ## \frac {1+v^2}{1+v}## - ##v##=x##\frac {dv}{dx}##
You forgot the single ##v##. It is ##v + \ldots ##. And once you have the form ##\ldots dx = \ldots dv## you cannot simply drop the ##d-##terms. You have to integrate them: ##\int \ldots dx = \int \ldots dv##
The corrected version is ok, except for the integration part with the ##dx## and ##dv##.
just check my previous comment, i took the ##v## to the rhs and solved algebraically...
ok, let me take a small break, i am doing all this in a rush hence the mistakes, we chat later...
Yes. When you (@chwala) have the equation in x and v separated, you should be getting
$$\frac{1 + v}{1 - v}dv = \frac {dx}x$$
From there, integrate, and then undo the substitution.
Likes chwala
##v=\dfrac{y}{x}##.
It's simpler to write the first equation as ##y = vx##, and then use the product rule rather than the quotient rule to get ##y' = v'x + v##
Yes, but you already did this earlier, so I gave the alternative. I thought it is less confusing: We substitute ##v## but differentiate ##vx##?
fresh_42 said:
I thought it is less confusing: We substitute v but differentiate vx.
I don't see any part of it that is confusing. We have v in terms of x and y (i.e., v = y/x). We can instead work with the equivalent* equation y = vx, and from it take derivatives, as I described.
* - equivalent in any interval for x that doesn't include 0
Both of us ended up with the same equation for y'. All I was saying that, all things being equal, using the product rule is to be preferred over using the quotient rule, as the latter is more involved and easier to get wrong.
It's not confusing me.
Funny thing is that it is upside down. While you can memorize the quotient rule, I always need to go with the product rule. Here we changed the parts.
Likes chwala
kindly check my post 18...i think it was just fine i have seen the error in typing ##(1-v^2)## in post 15... instead of ##(1-v)##...corrected in post 18...
  • #31
Close but wrong. We have ##\displaystyle{\int} \dfrac{dx}{x}= \ln x ## which you got right. But the other one is
\int \dfrac{1+v}{1-v} \,dv = \int \dfrac{dv}{1-v} + \int \dfrac{v}{1-v}\,dv = - \ln |1-v| +\, ?
The second integral doesn't result in a summand ##1-v##, which is what you got wrong. You can either solve ##\displaystyle{\int \dfrac{v}{1-v}\,dv}## by hand (integration by parts) or look it up in a table, e.g. Wikipedia, or check it with WolframAlpha.
Likes Delta2
  • #32
therefore, are you implying that if i use substitution,
##u=1-v, v= 1-u, dv=-du, y(1)=0##
##-∫\frac {2-u}{u} du##=∫##\frac {dx} {x}##
##-2ln u+u-ln x=k##
using the initial condition ##y(1)=0, k=1##
therefore,
##-2ln (1-v)+(1-v)-ln x=1##
##1-\frac {y}{x}##=##1+ln x+ln (1-\frac {y}{x})^2##
:wink: ok...i will look at this again...i always learn math by making mistakes..
  • #33
The initial condition is completely irrelevant here. It shouldn't play a role until after you have solved the differential equation in v and x, and then replaced v with y/x.
##-2ln u+u-ln x=k##
therefore,
Several posts back you gave the book's solution. Does your solution here match that one? You can always verify that a solution you find is actually a solution by 1) confirming that your solution matches the initial condition, and 2) by confirming that you can differentiate your solution to get back to the given differential equation.
  • #34
i think the textbook answer might be wrong unless i am missing something, let me post all my steps now. Further, i think the initial condition is necessary so as to arrive at a solution. give me a moment i post all my steps...
  • #35
now we have,
∫##\frac {1+v}{1-v} dv = ∫\frac {dx}{x}##
Let ##u=1-v##, →##du= -dv## →##v=1-u##
-∫##\frac {2-u}{u} du= ∫\frac {dx}{x}##
∫##(1-2u^-{1}) du= ∫\frac {dx}{x}##
##u-2ln u-ln x=k##
on using ##y(1)=0, k=1##
##(1-v)-ln(u)^2-ln x=1##
1-##\frac {y}{x}-ln(1-yx^-1)^2-ln x=1##
-##\frac {y}{x}= ln (1-yx^-1)^2+ln x##
-##\frac {y}{x}=ln x [\frac {x^2-2xy+y^2}{x^2}##]
##-y=xln [\frac {x^2-2xy+y^2}{x}##]
##y=-xln [\frac {x^2-2xy+y^2}{x}##]
now the above is my steps...
the textbook solution is
##y=x ln [\frac {x}{x^2-2xy+y^2}]##
  • #36
The textbook answer is correct. What do you get for ##\displaystyle{\int \dfrac{v}{1-v}\,dv}\;? ##
@Mark44 has told you the next steps:
Solve the integrals correctly! With constant term(s).
Undo the ##y \to v## substitution.
Apply the boundary conditions to specify the constants from integration.
Algebraically modify the result in order to get the form of the textbook answer.
But first solve the integral above.
  • #37
Bingo!
I just checked the two solutions! I got it, they're the same... Am in a meeting, by using the basic laws of logs, my solution can be expressed as the other. Therefore, I was just right. A quick way of proving is just by plugging arbitrary values for x and y in the two solutions!
  • #38
I think his is correct: ##-ln(b/a)=-( lnb-lna)=lna-lnb=ln(a/b).##
  • #39
That was not the problem. He wrote, at least the first time, that ##\displaystyle{\int \dfrac{v}{1-v}}\,dv = -(1-v)-\ln (1-v)## which is wrong on several levels: ##\displaystyle{\int \dfrac{v}{1-v}}\,dv = -v-\ln |1-v| + C##
But he edits his posts all the time and he doesn't always tell what he actually did, that I lost track. His first answer to the integral was wrong and if at all, he corrected it via edit, which makes the thread almost unreadable.
  • #40
Sorry, thanks for your insight though. I thought my post number 35 was clear. I even indicated that I would show all my steps,...
I've noted your concerns on editing posts. I will desist from it to avoid future confusion...
Likes fresh_42
  • #41
Or write in the post the fact that you are editing as well as the details of the edit.
  • #42
A new post is better, especially if there are already answers! And changing calculations forces readers to read the same calculation again and again. That will not work on the long run.
  • #43
I was referring to this post:
The integration is wrong here. It must not be ##-(1-v)## in the linear term, it has to be ##-v##.
Likes chwala
  • #44
@chwala , it might help you in future with such problems to see how the substitution y=vx can be spotted. One thing I check up front with a ODE is whether there is a consistent way of assigning dimension to the variables. In the present case, giving x and y the same dimension works out, suggesting solutions like y=Cx, for some constant. Indeed, C=1 is a solution.
To find more, you can look for variants such as y=xv (v having no dimension).
Had the original equation been dimensionally satisfied by y=x2, you might have tried y=x2v, etc.
Likes chwala
  • #45
Thanks haruspex, fresh and wwgd on your input on this problem. I have learned something on the approach... i guess i have to take time and avoid silly mistakes and math errors...
Likes WWGD
