Solve the given trigonometry equation
  • Thread starter Thread starter chwala
    Trigonometry
The discussion focuses on clarifying the use of cycles in trigonometric equations, particularly why tangent is considered with a factor of 2 instead of just π radians. The user expresses a preference for using π radians for simplicity. They also provide a known value for the inverse tangent function, which leads to solutions in the second and fourth quadrants. The derived equations for x incorporate a factor of 1/2 in the cycle, reflecting the periodic nature of the tangent function. The final solutions are constrained within the range of -10 to 0, yielding specific values for x.
chwala
see attached
Trigonometry
This is the problem. The question is simple i just need some clarification as indicated on the part highlighted below in red.
Now from my understanding tangent repeats on a cycle of ##π## radians...why do we have 2 the part circled in red below i.e ##2##? This is the part that i need clarity. Why consider cycles for sine and cosine here?
It's straightforward and less stressful to just use ##π##radians in my opinion.
The other form given below is the one that i know and am very much conversant with;
We know that ##\tan^{-1}####\left[-\dfrac{5}{9}\right]=-0.5071##.
Tangent is negative in the second and fourth quadrant respectively. This will realize the given values: ##-0.5071+π## and ##2π-0.5071## respectively... giving us the desired ##2.6345## and ##5.7761##
i.e
##2x=-0.5071+nπ⇒x=-0.25355+\dfrac{1}{2}nπ##
##2x=2.6345+nπ⇒x=1.31725+\dfrac{1}{2}nπ##
##2x=5.7761+nπ⇒x=2.88805+\dfrac{1}{2}nπ##
where ##n=0, ±1, ±2...## and given that the solution lies on ##-10≤x≤0## then we shall get the answers as shown on the text.
Cheers.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
