Solve Transmission Lines Homework: Coaxial Cable, 1kOhm, 10Ohm
  • Thread starter Thread starter shivik89
    Lines
A coaxial cable is driven by a pulse source with an internal impedance of 1 kOhm and a load impedance of 10 Ohm, while the characteristic impedance of the cable is 53 Ohm. The voltage at the end of the line needs to be sketched as a function of time for 250 ns, considering the reflection coefficients at both the input and output. The initial voltage division between the source resistance and the cable's characteristic impedance is calculated, leading to a forward traveling wave. The discussion emphasizes understanding how the voltage behaves at the start of the transmission line and what occurs when the wave reaches the load. The key focus is on determining the voltage profile over the specified time duration.
shivik89
can someone help me solving this problem ?
A coaxial cable is driven by a pulse source with internal impedance of
1kohms, 1 V amplitude, square wave with duration of both positive and negative pulse is
800 ns, with negligible rise- and fall-time. The load impedance is 10 ohm.The characteristic ipedance of the coax line is 53 ohms.
Sketch the voltage at the end of the line as function of time for 250 ns.
nS or uS?
Forum rules require you to at least make an attempt at a solution.
CWatters said:
nS or uS?
Thanks for the reply, can you help. it is asked in ns?I tried calculating the reflection coefficent at the input and output but can't get an idea how the voltage will look like
Ok what happens at the start of the transmission line - think potential divider.
I guess at start.The 1V will be divided between the source resitance of 1 kohms and the characteristic impedance of the cable of 53 ohms. so the forward traveling wave is 53/(1000+53) *1 V ?
Yes so a wave/step up of that magnitude sets off down the cable. What happens when it gets to the other end? And what's the voltage that end until it arrives.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
