Solved] Proving Linear Transformation Properties with Linear Independent Sets
  • Thread starter Thread starter amanda_ou812
    Linear Proofs
amanda_ou812
Let V and W be vector spaces and T: V-> W be linear.
a) Prove that T is one to one if and only if T carries linearly independent subsets of V onto linearly independent subsets of W.
b) Suppose that T is one to one and that S is a subset of V. Prove that S is linearly independent if and only if T(S) is linearly independent.
c) Suppose B = {v1, v2, ..., vn} is a basis for V and T is one to one and onto. Prove that T(B) = {T(v1), ..., T(vn)} is a basis for W.
1. nullity + rank = dim V
2. T is one to one if and only if N(T) = {0}
3. T is onto implies R(T) = W
4. R(T) = span (T(B))
5. there may be others
a) If T is one to one then N(T)) = {0} which implies that nullity = 0. Then we know that rank = dim V. This implies that T is onto (by a theorem in my text). This means that R(T) = W = span (T(B)) where B is a basis for V. So W = a T(v1) + ...+ a (sub n) T(vn) where B = {v1, ..., vn}. HERE is where I think I NEED another step before I can do the conclusion... So this shows that T carries linearly independent subsets of V onto linearly independent subsets of W
If T carries linearly independent subsets of V onto linearly independent subsets of W, then T is onto, which implies that R(T) = W. this implies that dim R(T) = rank = dim W which implies that rank = dim V and therefore T is one to one.
b) I do not have anything formal...just my thought process
So, I know T is one to one, S is a subset of V and S is linearly independent. So T is one to one implies that N(T) = {0} which implies that rank = dim V which implies that T is onto which implies that R(T) = W = span (T(B)) where B is a basis for V. So if S = B then we know that R(T) = W = span (T(S)). I know that S is linearly independent ... but how do i get to T(S) being linearly independent.
For the other way, I know T is one to one, S is a subset of V and T(S) is linearly independent. I know the same stuff as above but I do not know how T(S) linearly independent implies S is linearly independent.
c)
So, same thoughts here. T is one to one implies that N(T) = {0} which implies that rank = dim V. Also, T is onto which implies that R(T) = W = span (T(B)) where B is a basis for V. ok, so how do I show that it is a basis for W?
For c), suppose not. Suppose there is a vector T(vx), which can be expressed in terms of other T(vi). Knowing T is linear, what does that imply?
Then T is linearly dependent. So there exists lambda's, not all 0, such that the linear combination is 0. Also, if T is linearly dependent than v1, ..., vn are linearly dependent so then B is not a basis for V.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
