How Does Mass Transfer Between Rotating Drums Affect Their Angular Velocities?
  • Thread starter Thread starter Order
The discussion revolves around the dynamics of two rotating drums, where the inner drum loses mass in the form of sand that sticks to the outer drum. The user attempts to derive the angular velocities of both drums, initially focusing on the conservation of angular momentum. They present equations for angular momentum and derive expressions for the angular velocities, but encounter discrepancies with provided clues and an answer sheet. The user questions whether the angular momentum of the inner drum remains constant despite mass loss and seeks clarification on their calculations. The conversation highlights the complexities of mass transfer and its effects on angular velocities in rotating systems.
Order
Here is a problem I spent my sunday trying to solve. I made progress, but still something is wrong.
A drum of mass MA and radius a rotates freely with initial angular velocity \omega_{A}(0). A second drum with mass MB and radius b>a is mounted on the same axis and is at rest, although it is free to rotate. A thin layer of sand with mass MS is distributed on the inner surface of the smaller drum. At t=0 small perforations in the inner drum are opened. The sand starts to fly out at a constant rate \lambda and sticks to the outer drum. Find the subsequent angular velocities of the two drums \omega_{A} and \omega_{B}. Ignore the transit time of the sand.
Ans. clue. If \lambda t = M_{B} and b=2a then \omega_{B}=\omega_{A}(0)/8
\frac{dL}{dt}=0
L=mr^{2}\omega
I begin by looking at the angular momentum of the inner drum: L_{A}(t)=(M_{A}+M_{S}-\lambda t)a^{2}\omega_{A}(t) and at a later time L_{A}(t+\Delta t)=(M_{A}+M_{S}-\lambda (t+\Delta t))a^{2}\omega_{A}(t+\Delta t)+\lambda \Delta t a^{2}\omega_{A}(t). Taking the limit and dividing by dt gives \frac{dL_{A}}{dt}=(M_{A}+M{S}-\lambda t)a^{2}\frac{d\omega_{A}}{dt}-\omega_{A}\lambda a^{2}=0. This is a differential equation which can be solved by switching a little to give
\omega_{A}=\omega_{A}(0)\frac{M_{A}+M_{S}}{M_{A}+M_{S}-\lambda t}
I think this might be right.
However, the second part I am not so sure of. First of all some energy is lost when the sand falls in partly perpendicular to the surface of the outer drum. One can show that a fraction a/b of the momentum survives and the rest becomes heat. Therefore the angular momentum of the outer drum at time t will be L_{B}(t)=(\lambda t + M_{B})b^{2}\omega_{B}(t)+b\frac{a}{b}a\omega_{A} \lambda \Delta t, where the second term is the incoming sand losing some mechanical energy. At a later time L_{B}(t)=(\lambda (t+\Delta t) + M_{B})b^{2}\omega_{B}(t+\Delta t). Taking the limit and dividing by dt gives \frac{dL_{B}}{dt}=(\lambda t+M_{B})b^{2}\frac{d\omega_{B}}{dt}+\lambda(\omega_{B}b^{2}-\omega_{A}(0)a^{2}\frac{M_{A}+M_{S}}{M_{A}+M_{S}-\lambda t})=0 This is a linear differential equation which can be solved to give \omega_{B}(t)=\omega_{A}(0)\frac{a^{2}}{b^{2}}\ln \lgroup \frac{M_{A}+M_{S}}{M_{A}+M_{S}-\lambda t}\rgroup \frac{M_{A}+M_{S}}{M_{B}+\lambda t}
This is not in accordance with the clue, nor with my answer sheet that says \omega_{B}=\omega_{A}(0)\frac{a^{2}(M_{A}+M_{S}-\lambda t)}{b^{2}(M_{B}+\lambda t)}
Please tell me if something is unclear.
Isn't your first differential equation dWa/Wa=lambda*dt/(Ma+Ms-lambda*t)?
Yes it is \frac{d\omega_{A}}{\omega_{A}}=\lambda \frac{dt}{M_{A}+M_{S}-\lambda t} This leads to \ln \omega_{A}=-\ln (M_{A}+M_{S}-\lambda t)+C which leads to my equation stated in original post.
However I think that the angular momentum of the inner drum might be constant. This is because now looking closer at my equations LA(t) and LA(t+delta*t) I get a sign difference. L_{A}(t+\Delta t)-L_{A}(t)=(M_{A}+M_{S}-\lambda t)a^{2}(\omega_{A}(t+\Delta t)-\omega_{A}(t))+\lambda a^{2}\Delta t(\omega_{A}(t)-\omega_{A}(t+\Delta t)) Now the second term in this equation becomes zero when taking the limit, so (M_{A}+M_{S}-\lambda t)a^{2}\frac{d\omega_{A}}{dt}=0 with the only solution that the angular momentum is constant.
Now putting this into the differential eguation for the second drum \frac{d\omega_{B}}{dt}+\frac{\lambda}{\lambda t+M_{B}}\omega_{B}=\omega_{A}(0)\frac{a^{2}}{b^{2}}\frac{\lambda}{\lambda t+M_{B}}, with the solution \omega_{B}(t)=\omega_{A}(0)\frac{a^{2}}{b^{2}} \frac{\lambda t}{\lambda t+M_{B}} This is correct according to the answer clue but not according to my answer sheet. Do you think this might be right? Will a drum losing mass have a constant angular momentum?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
