Solving a Polynomial Division Problem: Remainder = 5 & 7
The discussion revolves around finding the remainder of the polynomial p(x) when divided by (x-1)(x+2), given that p(x) is expressed as (x-1)(x-2)q(x) + 2x + 3. The key point is that the remainders for (x-1) and (x+2) are specified as 5 and 7, respectively. Participants clarify that when dividing by (x-1)(x-2), the term q(x) becomes irrelevant since it evaluates to zero at the roots of the divisor. The consensus is that the remainder when p(x) is divided by (x-1)(x-2) is simply 2x + 3, which aligns with the polynomial division principles discussed. Understanding the role of q(x) in the division process is crucial for solving the problem correctly.
misogynisticfeminist
Given that a polymial p(x) is
p(x)= (x-1)(x-2) q(x) + 2x+3
where q(x) is also a polynomial
Find the remainder when p(x) is divided by (x-1)(x+2) where the remainder divided by (x-1) and (x+2) is both 5 and 7 respectively. I don't know even where to start ! so please help, thanks alot.
Consider this,
P(x) = (x-1)(x+2)Q(x) + ax + b
Find P(1) and P(-2) (You know the remainders , since u know them , try to find a and b).
-- AI
Check your problem again. I suspect that p(x)= (x-1)(x+2)q(x)+ 2x+ 3 (or, conversely, you want to divide by (x-1)(x-2)). That way, the remainders are 5 and 7 as you say, no matter what q(x) is. The "quotient" when divided by (x-1)(x+2) is q(x) and the remainder is just 2x+ 3.
Halls, actually its really meant to be (x-2) but yes, the answer you gave is right too, but one thing still baffles me. If say,
\frac {(x-1)(x-2) q(x) + 2x+3}{(x-1)(x-2)}
I cannot factor out (x-1)(x-2) so that they can cancel out in the fraction and then I get 2x+3.
And I understand why when you divide (x-1) and (x-2) individually q(x) can be ignored because it is multiplied by zero. But why is q(x) ignored when it is divided by the product of (x-1) and (x-2)?
One way to think abt it,
Dividend = Divisor * Quotient + Remainder.
Another way to think abt it,
Let Q'(x) = (x-1)(x-2)Q(x)
P(x) = Q('x) + 2x + 3
Q'(x) will give remainder 0 when divided by (x-1)(x-2) thereby P(x) will give remainder 2x+3.
-- AI
