Solving an Equation with Cosine
  • Thread starter Thread starter salman213
    Cosine
The equation x = rcos(a)cos(a) leads to the expression -2/7 = cos^2(a), which cannot yield a real solution since cos^2(a) must be non-negative. The user initially misapplied the identity for cos^2(a), but later clarified the correct formula. The realization that cos(a) cannot be squared to produce a negative value indicates that the equation has no real solutions. Ultimately, the user resolved their confusion regarding the interpretation of the solution. The discussion highlights the importance of correctly applying trigonometric identities in solving equations.
salman213
1.x = rcos(a)cos(a)
x is known
r is known
I can't seem to get this!
x = -2
r = 7
therefore
-2/7 = cos(a)*cos(a)
so..
-2/7 = cos^2(a)
i know cos^2(a) = 1 + cos2a / 2
-2/7 = 1 + cos2a / 2
so
-4/7 -1 = cos2a
I cannot take cos inverse of this value since it is "greater" than 1 (-1.57)
the book says the angle is 106.6 degrees!
HELP!
Here's your problem right here:
Nope, it's \cos^2(a)=(1+\cos(2a))/2. Both terms are divided by 2.
yea sorry that's what i meant
but it still doesn't work out..
Egad, you have an even more serious problem that I missed.
You can't square cos(a) and get a negative number. This equation has no solution in the real numbers.
Who is Egad?EDITED!
NEVERMIND I figured it out, i was interpreting the solution incorrectly...
Thanks anyways!
salman213 said:
Who is Egad?
:smile: "egad" is an exclamation like "crikey" or "blimey".
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
