Solving an Integral Involving $\Theta$ and $u$ - Seeking Assistance
The discussion revolves around solving an integral involving the variable transformation from \( u \) to \( \Theta \). The integral presented is \(\int_{R_{0}}^{R(\Theta)}\frac{du}{u\sqrt{a^2-u^2}}\), with the transformation \( u = a\sin{\Theta} \). Participants suggest using trigonometric identities and constructing a triangle to facilitate the conversion back to the original variable. The key point is to express \(\csc{\Theta}\) in terms of \( u \) and apply the substitution correctly to simplify the expression. Overall, the conversation emphasizes the importance of using trigonometric relationships to resolve the integration challenge.
Odyssey
Hi, I carried out the integration until the very end...I don't know how to convert the variable back to the original one. :confused:
Let u = a\sin{\Theta}
du = a\cos{\Theta}d\Theta
The integral becomes...
\int_{R_{0}}^{R(\Theta)}\frac{a\cos{\Theta}d\Theta}{a\cos{\Theta}a\sin{\Theta}}
\frac{1}{a}\int_{R_{0}}^{R(\Theta)}\csc{\Theta}d{\Theta}
\csc{\Theta}d{\Theta} = \ln {|\csc{\Theta}-\cot{\Theta}|}+C
This is where I'm stuck. I don't know how to convert the thetas back into the "u"s. I haven't multiplied the answer by 1/a yet. I know that \Theta=\sin^{-1}{u/a}, but if I plug the \sin^{-1}{u/a} into Theta, the expression becomes super messy and I really don't know what to do with it.
Please help, thanks in advance! :smile:
make a triangle.. it's the only way. For example, if theta = arcsin(u/a) then sin(arcsin(u/a)) = u/a, cos(arcsin(u/a)) = sqrt(a^2-u^2)/a. Make a triangle with sides u, sqrt(a^2-u^2) and a. You can find all the trig functions from it (be sure to label theta)
Hi there, it looks like you're on the right track! To convert back to the original variable, we can use the trigonometric identity \csc{\Theta} = \frac{1}{\sin{\Theta}}. Then, we can substitute in for \Theta using \Theta = \sin^{-1}{\frac{u}{a}}. This will give us:
\int_{R_{0}}^{R(\Theta)}\frac{1}{a\sin{\Theta}}d{\Theta} = \frac{1}{a}\int_{R_{0}}^{R(\Theta)}\frac{1}{\sin{\Theta}}d{\Theta} = \frac{1}{a}\int_{R_{0}}^{R(u/a)}\frac{1}{\frac{u}{a}}d{\frac{u}{a}} = \frac{1}{a}\int_{R_{0}}^{R(u/a)}\frac{1}{u}du
Then, we can use the substitution u = a\sin{\Theta} again to get back to the original variable. This will give us:
\frac{1}{a}\int_{R_{0}}^{R(u/a)}\frac{1}{u}du = \frac{1}{a}\int_{R_{0}}^{R(\Theta)}\frac{1}{a\sin{\Theta}}d{\Theta} = \frac{1}{a}\int_{R_{0}}^{R(\Theta)}\frac{1}{u\sqrt{a^2-u^2}}du
I hope this helps! Let me know if you have any other questions. Good luck with your integration!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
