Solving an integral using a*sinh substitution
Telemachus
The statement says: Calculate the next integrals using the adequate trigonometric substitution:
\displaystyle\int_{}^{}x^2\sqrt[ ]{x^2+3}dx
ch^2(t)-sh^2(t)=1\Rightarrow{ch(t)=\sqrt[ ]{1+sh^2(t)}}
x=\sqrt[ ]{3}sh(t)
dx=\sqrt[ ]{3}ch(t)dt
u=ch(t)
du=sh(t)dt
dv=ch(t)dt
v=sh(t)
\displaystyle\int_{}^{}ch^2(t)dt=ch(t)sh(t)-\displaystyle\int_{}^{}sh(t)sh(t)dt
\displaystyle\int_{}^{}ch^2(t)dt=ch(t)sh(t)-\displaystyle\int_{}^{}sh^2(t)dt=ch(t)sh(t)-\displaystyle\int_{}^{}(ch^2(t)-1)dt
* \displaystyle\int_{}^{}ch^2(t)dt=\displaystyle\frac{1}{2}(ch(t)sh(t)+t)
9\displaystyle\int_{}^{}sh^2(t)ch^2(t)dt=9(\displaystyle\frac{sh^2(t)}{2}ch(t)sh(t)+t)-\displaystyle\int_{}^{}(ch(t)sh(t)+t)sh(t)ch(t)dt=9(\displaystyle\frac{sh^2(t)}{2}ch(t)sh(t)+t)-\displaystyle\int_{}^{}ch(t)^2sh(t)^2dt-\displaystyle\int_{}^{}ch(t)sh(t)tdt
Well, if you see an easier way of solving this let me know :P
Bye there!
You might want to try the substitution x=\sqrt{3}\tan \theta instead.
Or you could use your substitution and use the identities
\sinh 2x = 2\sinh x\cosh x
\sinh^2 x = \frac{\cosh 2x-1}{2}
instead of integration by parts.
Thanks vela. I'll try both ways.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
