Solving equation involving a variable and its logarithm
JulieK
Can you suggest a general analytical solution to the following equation
\ln(x^{3/2})-bx-c=0
where x is real positive variable and b and c are real positive
constants.
There is no analytical solution. It should be solved numerically.
Sure - it is the intersection of ##y=\ln(x)## with the line ##y=2(bx+c)/3##.
Note: ##\ln(x)## is only defined for ##x>0##.
Solutions will not exist for all a and b.
In general you'll need a numerical solution.
You're probably right, but ... can you prove it?
Depends on whether or not you classify the Lambert W function as an analytical solution (I doubt the mathematics community does).
$$\ln(x^{\frac{3}{2}}) = b x + c \\
x = \exp( \frac{2}{3}bx + \frac{2}{3}c) \\
x \exp(- \frac{2}{3} bx) = \exp( \frac{2}{3}c) \\
- \frac{2}{3} b x \exp(- \frac{2}{3}bx) = -\frac{2}{3} b \exp( \frac{2}{3}c) \\
- \frac{2}{3} b x = W_n(-\frac{2}{3} b \exp( \frac{2}{3}c)) \\
x = - \frac{3 W_n(-\frac{2}{3} b \exp( \frac{2}{3}c))}{2 b}$$
For a real x > 0, b \neq 0 and n \in \mathbb{Z}. Only n=-1, 0 can provide real solutions, though.
The W-function is certainly an analytic function so I would call that an "analytic solution".
Looks like confusion between "analytic function" and "analytic expression".
