Solving equations simultaneously
  • Thread starter Thread starter jstevenson16
    Solving equations
To find the downward acceleration of the cylinder and the tension in the string, start with the equations of motion: the sum of forces in the vertical direction (Mg - T = Ma) and the torque equation (TR = Iα). Substitute the moment of inertia (I = 1/2 MR²) and relate angular acceleration (α) to linear acceleration (a) using the equation a = Rα. By substituting α with a/R in the torque equation, you can express tension (T) in terms of acceleration. Finally, substitute this expression for T back into the force equation to solve for both the acceleration and tension.
jstevenson16
Problem:
You make a primitive yo-yo by wrapping a massless string around a solid cylinder of mass M and radius R. You hold the freee end of the string stationary and release the cylinder from rest. The string unwinds but does not slip of stretch as the cylinder descends and rotates. Find the downward acceleration of the cylinder and the tension in the string.
Necessary Equations/Attempt
I have so far found the translational and rotational forces to be as follows:
ƩFy=Mg-T=Macm-y
Ʃτz=TR=Iαz
I know that I=1/2MR2
and have determined that acm-y=Rαz
The issue I'm having is with solving the two equations simultaneously to find the target variables. Can anyone offer a guided explanation of how to do this or walk me through it? I have a final tomorrow and just realized I still can't figure it out. Any help is much appreciated!
jstevenson16 said:
Problem:
ƩFy=Mg-T=Macm-y
Ʃτz=TR=Iαz
Mg-T=Ma
TR=Iα
a=αR
You have these three equations. Replace α with a/R in the second equation, and divide by R. You get an expression for T. Substitute 1/2 MR2 for I. Substitute the expression for T in the first equation.
ehild
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
