Solving for 2 Unknowns with 3 Equations and Sine Functions
  • Thread starter Thread starter boeledi
    Sine
The discussion focuses on solving a system of three equations with two unknowns and constants A and C. The equations involve sine functions and require applying trigonometric identities to simplify the expressions. Participants suggest combining the equations to eliminate one variable, which allows for back substitution to isolate the remaining variables. The goal is to reduce the system to a manageable form that can be solved for the unknowns. Ultimately, the process requires careful manipulation of the equations and sufficient time for calculations.
boeledi
Could someone help me find the solution of this ?
x - y + z - 2 A sin(y+z) = C
-x - y - z - 2 A sin(x+z) = C
-x + y + z - 2 A sin(x+y) = C
Where C and A are constant ?
Many thanks
Mathematics news on Phys.org
could you please confirm that the second line is not x + y - z ...
Sorry, based on your question, I did my calculations again and ... The real system is:
-x + y + z + 2A sin(y-z) = C
-x + y - z + 2A sin(x-z) = C
x + y - z + 2A sin(x-y) = C
where A and C are constant.
Could you please help me?
I would start by applying the trigonometric identities for sin(a+b) then add the first 2 equations together. I think several terms will drop out, you then should be able to repeat the process with the 3rd equation. The goal is to eliminate one of the variables, when you have an expression involving 2 variables solve for 1 of them, then use that to back substitute isolating the remaining variables.
5 unkowns
2 of which are constant
3 equations
combine 3 equations, you will be left with 2 unkowns (your two constants)
And you are done... all you need is the time to solve it.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
