Variable Homework: Solving for m1 in Gm1m2/r^2
  • Thread starter honphysics12
  • Tags
    Variable
In summary, to solve for m1 in the equation f= Gm1m2 / r squared, you can use simple algebra and the property that for any real numbers a and k, both not equal to zero, a*(1/k)*k=a. By rearranging the equation, you can isolate m1 and solve for it.
honphysics12
Solve for m1: f= Gm1m2 / r squared
How do you solve this?
where is your attempt?
work must be shown b4 we can help, thanks!
I have no idea how to solve it.
here's a hint: Gm1m2 is simply G times m1 times m2
now what would your steps be?
Are you kidding? This is very simple algebra. Do you know that for any real numbers a and k, both of them not equal to zero, a*(1/k)*k=a ?
You want m1, but you have it on the right-hand side being multiplied by Gm2/(r^2)
(the digits shown in your equation must be assumed as subscripts; if we use TEX or LaTex, we could show that more clearly)
Or by using these tags
- Subscript
- Superscript
The corresponding end tags have a forward slash (/) in front of sub and sup.
Examples: m1 m2
Related to Variable Homework: Solving for m1 in Gm1m2/r^2
What is "Solving For A Variable"?
"Solving For A Variable" is the process of finding the value of a variable in an equation or formula. It involves using algebraic techniques to isolate the variable on one side of the equation, in order to determine its value.
Why is "Solving For A Variable" important in science?
"Solving For A Variable" is important in science because it allows us to manipulate and understand mathematical relationships between variables. This is crucial in many scientific fields, such as physics and chemistry, where equations and formulas are used to describe the behavior of natural phenomena.
What are the steps involved in "Solving For A Variable"?
The steps involved in "Solving For A Variable" may vary slightly depending on the specific equation or formula, but generally they include identifying the variable, isolating the variable by performing inverse operations, and checking the solution to ensure it is valid within the context of the problem.
What are some common mistakes to avoid when "Solving For A Variable"?
Some common mistakes to avoid when "Solving For A Variable" include incorrectly applying algebraic rules, forgetting to perform inverse operations on both sides of the equation, and making arithmetic errors. It is also important to check the solution and make sure it makes sense in the context of the problem.
How can "Solving For A Variable" be applied in real life?
"Solving For A Variable" can be applied in real life in various ways, such as calculating the dosage of medication based on body weight, determining the amount of ingredients needed for a recipe, or finding the optimal pricing for a product based on production costs and desired profit. It is a useful skill in problem solving and decision making in many fields, including finance, engineering, and economics.
