Solving for Orthogonal Trajectories
5 replies · 7K views · last reply
vorse
Which of the following is the set of orthogonal trajectories for the family indicated by
(x-c)^2 + y^2 = c^2
a). (x-c)^2 + y^2 = c^2
b). (x-c)^2 - y^2 = c^2
c). x^2 + (y-c)^2 = c^2
d). x^2 - (y-c)^2 = c^2
e). None of the above
I think this is a homogenous equation after playing with the variables and substituting for C. I came up with:
y' = (y^2 - x^2)/xy
I then substitute y=xv after setting y' = 1/y' for the orthogonal trajectories and tried to solve the equation, but ended up with answers no where close to the choices.
Hi vorse! :smile:
Let's do it the easy way :wink: …
draw a few curves, and that should show you the most obvious orthogonal trajectory …
which of a) to e) does that one lie on? :smile:
I was afraid you'd said I have to graph the equation; I can never make heads to tail of what I draw out.
ok … (x-c)2 + y2 = c2 is obviously a circle.
So, for each value of c, what is its centre, what is its radius, and what are the endpoints of its "horizontal" diameter?
Ok, I figured out the answer. I think it's answer choice C. It's just my answer has something like 2c as one of the constant, and I guess the answer choice reduce it down to just C. Btw, I didn't graph the equation; it is a homogenous equation and can be solve that way; just the algebra manipulation was confusing. Thanks for all the help PF. Thanks for trying to help me tiny tim.
Yup! :smile:
But a quick sketch always helps …
in this case, the original curves are the circles with centres on the x-axis, all touching each other (and the y-axis) at the origin.
Quickly hovering over this with a pencil shows that the orthogonal trajectories must approach the y-axis horizontally, and must all go through the origin …
which choice C does, since it's the circles with centres on the y-axis. :wink:
hmm … are those all of the orthogonal trajectories?
(btw, the wiki page http://en.wikipedia.org/wiki/Orthogonal_trajectories" )
