Solving for the Alaskan Rescue Team Equation
  • Thread starter Thread starter Let It Be
An Alaskan rescue team drops a package from a plane flying horizontally at 40 m/s from a height of 100 m. The discussion focuses on calculating where the package will land and its velocity components just before impact. Participants express confusion over using the correct equations for vertical motion and the initial conditions, noting that the vertical velocity is zero at the moment of release. Clarification is provided that 100 m is the vertical distance and 40 m/s is the horizontal velocity. The conversation emphasizes the need to solve the equations for time of flight and displacement accurately.
Let It Be
1. An Alaskan rescue team drops a package of emergency rations to a stranded hiker. The plane is traveling horizontally at 40 m/s at a height of 100m above the ground. A) Where does the package strik the ground relative to the point at which it was released? B) What are the horizontal and vertical components of the velocity of the package just before it hits the ground?
2. H=1/2gt^2
ΔX=ViTf+1/2ATf^2
AND apparently ΔY=ViTf+1/2ATf^2
3. So I'm not quite sure why you can't use the free fall equation...that was my first guess but it just seems too easy. The book says to use the third equation I put above, however I don't know how to completely solve it.
I got this far...
ΔY=ViTf+1/2ATf^2
100=?(would the Vi be 40m/s??)Tf+1/2(9.8)Tf^2
I know I'll end up with a Tf & Tf^2 on the right side of the equation, but I don't know what to do to solve.
Right, and then part B I'm soooo lost
Let It Be said:
1. An Alaskan rescue team drops a package of emergency rations to a stranded hiker. The plane is traveling horizontally at 40 m/s at a height of 100m above the ground. A) Where does the package strik the ground relative to the point at which it was released? B) What are the horizontal and vertical components of the velocity of the package just before it hits the ground?2. H=1/2gt^2
ΔX=ViTf+1/2ATf^2
AND apparently ΔY=ViTf+1/2ATf^23. So I'm not quite sure why you can't use the free fall equation...that was my first guess but it just seems too easy. The book says to use the third equation I put above, however I don't know how to completely solve it.
I got this far...
ΔY=ViTf+1/2ATf^2
100m is vertical or horizontal?
40m/s is vertical or horizontal velocity?
PS: This ques is just like rolling marble ques.
100m is vertical
40m/s is horizontal
Could you help me figure out how to solve the ΔY=ViTf+1/2ATf^2 part please
P.P.S-Really? In that one I had to find Vi too...
Let It Be said:
100m is vertical
40m/s is horizontal
here also you have it
initial horizontal velocity is same as of _____
and initial vertical is 0 as it is just dropped
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
