Solving for Velocity: Kinetic Energy and Rest Energy Relationship Explained
  • Thread starter Thread starter chris_0101
    Velocity
The discussion revolves around solving for velocity in the kinetic energy equation K = [(mc^2)/sqrt(1-((v^2)/(c^2))] - mc^2. The user initially misapplied the equation, leading to confusion regarding the correct expression for velocity. After realizing the need to multiply -mc^2 by the square root term, the user found the correct approach to isolate v. The textbook's answer for velocity is v = c(sqrt(1 - [1 / (1 +K/mc^2)^2])). The clarification helped resolve the user's issue effectively.
chris_0101
I need help solving for velocity from the equation K = [(mc^2)/sqrt(1-((v^2)/(c^2))] - mc^2
where mc^2 is the rest energy​
K is the kinetic energy​
K[sqrt(1-((v^2)/(c^2))] = (mc^2) - mc^2
sqrt(1-((v^2)/(c^2)) = [mc^2 - mc^2] / K
1-((v^2)/(c^2)) = [(mc^2 - mc^2)/K]^2
v = sqrt(1-c^2[[(mc^2 - mc^2)/K]^2] ------ final answer
However, my textbook has a different answer, which is:
Any help will be greatly appreciated, Thanks
K[sqrt(1-((v^2)/(c^2))] = (mc^2) - mc^2 <------------ HERE
On the second line, for forgot to multiply -mc^2 by [sqrt(1-((v^2)/(c^2))].
It should be K[sqrt(1-((v^2)/(c^2))] = (mc^2) - mc^2[sqrt(1-((v^2)/(c^2))]
Thanks, it worked out now
