Solving Friction: Finding the Horizontal Force
  • Thread starter Thread starter homevolend
    Friction
To find the horizontal frictional force on a 50 kg crate being pulled with a 200 N force at a 30-degree angle, the net force must first be calculated. The gravitational force is determined to be 490 N, and the normal force is adjusted by considering the vertical component of the pulling force. A free body diagram is essential for visualizing the forces acting on the crate. The frictional force can then be calculated using the coefficient of kinetic friction, which is 0.30. Properly summing the forces will yield the correct horizontal frictional force.
homevolend
A boy puls a 50 kilogram crate across a level a level floor with a force of 200N. If the force acts at an angle of 30degrees up from the horizontel, and the coefficient of kinetic friction is 0.30. find the horizontal frictional force exerted on the crate by the floor.
Ff=Fnet-Fa
I have tried many things to find the friction. First I found the fnet by doing
fg=mg
fg=50(9.81)
fg=490N
0=FN+Fasin(-)-Fg
0=FN+200sin30-490
0=Fn+100-490
-100=-490FN
FN=390N
Now we have the Fnet I tried to do the Fn-Fa for the friction but it didn't work. 390-200 gives 190 but then I did the rest of the equation and it doesn't work properly.
How do I find friction.
you first need to draw a free body diagram relevant to teh horzontal before you can slove anything!.. the Fnet is just the sum of all the forces acting into opposite direction so you just need to add your forces
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
