goonking
- 434
- 3
I chose the answer A, but it's not correct, can anyone explain why?
yes, Brobphy said:Is there a better answer?
"directly above" in this problem is intended to mean "straight above" i.e. above and not offset a little to one side or the other.goonking said:I shouldn't say the center of mass of the chain is right below my hand, can I?
ok, just making sure. makes sense since you can't hold up a chain with using just 1 point of contact.robphy said:The question says "balance[d]... on top of your finger" (implying a single point of contact).
goonking said:ok, just making sure. makes sense since you can't hold up a chain with using just 1 point of contact.
yes, actually you can, if you put your finger under one of the 'holes' , then would I say the center of mass is still directly above my finger?jbriggs444 said:Sure you can. But how is that relevant?
The center of mass would be directly above the point at which the floor and cone contact. Refer to post #5 for a definition of "directly above".goonking said:lets say I balanced a ice cream cone on the floor:
would the center of mass still be at the point where the floor and cone contact?
i understand now, tyjbriggs444 said:The center of mass would be directly above the point at which the floor and cone contact. Refer to post #5 for a definition of "directly above".
No.goonking said:so there can be an even better answer : the center of mass of the bat is directly above my finger, and at the heavier, thicker end of the bat, correct?
