Solving Momentum Problems: Questions & Answers
  • Thread starter Thread starter Beowulf
    Momentum
The discussion focuses on solving momentum-related physics problems, with specific questions regarding calculations involving mass, velocity, and momentum. Participants emphasize the importance of understanding key formulas, such as momentum (p = mv), change in momentum (Δp = Ft), and the conservation of momentum. Several examples are provided, including scenarios involving a car, cannon, bullet, canoe, and projectile, each requiring the application of these principles. The conversation stresses the need for a foundational understanding of these concepts rather than simply seeking answers. Overall, the thread serves as a guide to approaching momentum problems effectively.
Beowulf
I need help with some momentum questions and the formulas i need to use to find the answers.
1. A car weighting 15,680 N and moving at 20 m/s is actd upon by a 6.4 x 10^2 N force until it is brought to a halt.
a. What is the car's mass? 1600Kg?
b. What is its initial momentum?
c. What is the change in car's momentum?
d. How long does the braking force act on the car to bring it to a halt?
2. A cannon on wheels fires a cannonball with a mass of 10 kg at a velocity of 20 m/s, horizontally. The cannon's recoil velocity is 1.5 m/s. What is the cannon's mass?
3. A 35 g bullet moving at 475 m/s strikes a 2.5 kg wooden block. The bullet passes througgh the block , leaving at 275 m/s. The block was at rest when it was hit. How fast is it moving when the bullet leaves?
4. Two campers dock a canoe. One camper steps onto the dock. This camper has a mass of 80 kg and moves forward at 4 m/s. With what speed and direction do the canoe and the other camper move if their combined mass is 110 kg?
5. A 50 g projectile is launched with a horizontal velocity of 647 m/s from a 4.65 kg launcher moving at 2 m/s. What is the velocity of the launcher after the projectile is launched?
6. A 6kg object, A, moving at velocity 3.0 m/s, collides with a 6.0 kg object, B, at rest. After the collision A moves off in a direction 40(degrees) to the left of its original direction. B moves off in a direction 50(degrees) to the righ tof A's original direction.
a. Draw a vector diagram and determine the momenta of object and object B.
b. What is the velocity of each object after the collision?
we are not here to answer your hw, we are here helping you to understand physics, if you just want someone finish it for you , you come to a wrong forum. I will not answer your question unless you point out which part you do not understand...
I'm not asking for the answers to my questions. What I'm asking is how to solve those individual questions. For example what formulas to use and if I should be converting from grams to kilograms. Well mostly on how to approach each question since I seem to be completely lost with momentun. I know that it seems I just copied all the questions I had but I've finished some that I understood already and this are the ones that I'm completely lost with.
so surprise no one answer your question till now, usually people reply this types of question within 10 mins, let me give you some hints
p(momentum)=m(mass)*v(velocity) (1)
\Delta p (change of momentum) = F(force)*t(time) (2)
F(force)=m(mass)*a(accelaration) (3)
and most important, the conservation of momentum (if you don't know what this is, go back to your textbook and read, this is the most important part at your stage)
hints:
1a, weight is a force which equal to mg, don't ask me what g is...
1b, what is the formulas of momentum?
1c, the car finally stop, which means its final momentum is..., and the change of momentum is just the different between final momentum and initial momentum
1d, formulas (2) will help you in this case.
2. use the conservation of momentum.
3. use the conservation law again
4,5 and 6, conservation, conservation,conservation.
Ps. on question 5, change grams into kilograms... 1kg=1000g
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
