Solving Motor Braking Circuit Problem in Bowling Industry
264 replies · 30K views · last reply
jim hardy said:
If so, you seem to have fixed a contact race.
It's the jumper from 43 NO to the 31 NC of relay
H012 said:
o put it simply, I fixed the contact race and took the 25 amps out of the braking NC'd I put to new cube relay in sweep we'll see if it changes anything. Does my idea sound OK to you?
If i understand where your new contact is, where i guessed it, that sounds fine. Great thinking !
What powers the timer's coil ?
My curiosity always wants to understand what was going on,
that's why I'm curious about what circuit drives the relay coil and just how sharp is its turn-off , ie how fast does it drive relay coil current to zero.
Trying to upload a picture. Having hard time
I just jumped from relay contact to timer contact.
yes that looks right were you're indicating on attachment.
Finally got it to upload photo
  • Hand-drawn wiring sketch comparing an existing contactor labelled Existing with a new contactor labelled New, each with numbered terminals 13, 21, 31, 43 on top and 14, 22, 32, 44 below, with Power wires connected to the bottom terminal 44 on each, and a small auxiliary block at the top with wires looping to the new contactor's upper terminals.
Hmmm at this moment it looks like you've broken up a relay contact race between one contact getting opened(the NC?) before other gets closed(the NO?).
Which makes one wonder why they paralleled two NO contacts in upper left on both Table and Sweep motors.
Do you think it could have been a desperate attempt to make them share load ? Like maybe they noticed arcing at factory prototype test time ?
Wiring schematic titled Motor Circuits, Fig. 3, showing the sweep motor circuit with main and start windings, relay contacts, and a hand-added box labelled new timer with a question mark.
why there's a race is speculation
and of course it was my speculation so I'm biased toward it
what powers your timer coil ?
What do you think ?
old jim
What do you think ?
old jim
sharing the load maybe although that wouldn't be smart on their part as all the 115 power for the relays and other 115 V circuits in the chassis come off one common terminal strip. I've always wondered about it.
The timer coil is running to the sweep relay coil power. That way when relay closes the NO's on sweep relay the timer is set to wait until motor start circuit 25 amps is gone so that load isn't there on the NC when it opens.
Took awhile to figure start winding are engaged .05 sec which is what I have the delay set at. Hope I make sense. I tend to ramble on I think.
How'd you figure that out ?
Anyhow, if it stops the melting that's a REAL STRONG clue to something .
Congratulations ! Good thinking .
Any clues on that relay driver in the microprocessor ?
Did you manually cycle a relay and watch contacts to verify no overlap either direction, that is never a NO and NC contact both closed at same time ?
old jim
H012 said:
To put it simply, I fixed the contact race and took the 25 amps out of the braking NC'd I put to new cube relay in sweep we'll see if it changes anything. Does my idea sound OK to you?
Almost Anything that works is OK! Nice going.
But this is the first we have heard about 25 Amps as the contacts were opening. I even used the Search function on this thread and found nothing.
In general, relays should not overlap their contact timing unless specified when ordering. Can you give us the the part No. of the relay that was ordered, and/or the number on the box, and/or the numbers on the contact block? Any and all info will be helpful. Something very strange is going on.
Did you try replacing the MOV before making this change? If it failed it could/would show similar symptoms.
In post #207 you stated the MOV is OK. But didn't answer my question in post #215 of how you checked it. An open failure may not be visible.
Break before make. Both NO and NC should be unmade mid travel both directions.
Overlap contacts do exist in Allen-Bradley world.
Excerpt from a product catalog reading: OVERLAP CONTACTS: Overlap contacts (normally open contact closes before the normally closed contact opens) can be supplied. See page 9-133 for information on kits for field installation of overlap contact cartridges. Below it is a partly visible heading: Location of contacts in 3-pole relay.
When nothing will show itself wrong you have to make everything show itself right. Check a relay for overlap.
Also we had way way back a question about an extra wire..
about post 127 or 128
The 25 amps motor start exist at the NC opening when of course NO close due to a jumper from NO to NC. Yes there probably is an overlap but my thinking is that the 25 amps doesn't need to be at the NC's at all
Regardless of overlap. Also my thinking is that this time element that overlap occurs,
Is it enough to eliminate a chance of ionanation as the NC open? As far as checking the MOV I just checked continuity.
Tom/ Jim these are just my brain thinking trying to look at this as the sweep is running.
Is that this one ?i can't keep those contact numbers straight
Annotated wiring diagram labelled Fig. 3, Motor Circuits, for a sweep motor, with red and orange traces showing a circuit path and a green-outlined jumper labelled NO to NC, 12 or 42 to 31.
i can't keep those relay contact numbers straight.
Hand-drawn wiring diagram of two relays labelled S and T, each with a row of terminals; a red loop marks a link on S, with a green arrow and the words "This one?" pointing to it, an orange wire runs from S to T, and a blue wire runs from T's top terminal to a question mark.
Sure sounds like those contacts overlap for some reason. How does complete relay part number break down regarding overlap contacts? That AB bulletin is brutal to work through.
jim hardy said:
Is that this one ?i can't keep those contact numbers straightView attachment 107092
That's it
H012 said:
That's it
That's what I mean the specs for the relays are out of my league! I tried looking up relay overlap forget it!
spec sheet didnt even mention overlap that i could find
that snip i put up showing "overlap" contacts versus "standard" came out of a selection guide that for some reason isn't in the technical bulletin / specs we've been studying . I guess they figure a contact is a contact and it's some other part that controls whether it overlaps another contact.
<Rant>Very frustrating. I never heard them called that before, I'm used to "Break before Make" not "Standard" and "Make before Break" not "Overlap".
I think motorcycle gear shifters belong on the right hand side, too. <EndRant>
Used to be when i got this confused i'd sit down with a relay and the box it came in and the purchase order for it, cross check part number versus catalog number &purchase ordwr versus what the words say about contact operation and verify that by watching the contacts move as i depress the solenoid plunger. But that was in the power plant where everything was as over-documented as military gear. As you see fr some similar relays a simple 0 or 1 buried in the catalog number changes what you get from "Break Before Make" to "Make Before Break".
Sometimes the catalog number isn't on the part because it's made from subassemblies each bearing its own part number.
Is there a picture of the relay that melts its contacts someplace in this thread with a part number on it ? Do we know the complete catalog number that your parts guys are sending? Could they be off by that one digit ?
Did you ever watch the contacts while slowly depressing the solenoid button to see whether they're Break before Make or Make before Break ?
Photo of a black contactor with exposed terminals, showing a plunger in its housing and a label reading BUL 700; overlaid text asks whether a button or plunger extension can be pressed to operate the contacts.
As stated before I used two meters one on NO and one on NC watched continuity. By watching I could not tell if make before break occurred. It happens too fast. I'm using analog meters. With the new relays you can't see the contacts. I have had all makes of relays the most common are the AB 700CF.
Ok
Here is what I did: I mounted a Siemens 3TH4022-0A it's the only relay I have its old but OK for test. I mounted to a board then made a z bracket with a screw that will allow me to adjust it to push down on button on top of relay. What I found was NC open before NO close. There is actually a position Where it's neutral all 4 are open..
Okay, thanks . That relay doesn't "overlap", it's break before ,make which they seem to call "fixed" .
Number agrees with their catalog
http://www.datasheet4u.com/download_new.php?id=661606
Catalog table of relays with screw terminals for DIN rail, listing contact codes (NO/NC), early make and late break options, and catalog numbers with prices; red circles and underlines mark some rows.
AB700CF i can't find any mention of Make before Break. so for now i'll just hope it's not an option and one of the other ideas is what's been killing contacts..
That delay you put in sounds like the right approach to fixing a contact race.
Time will tell.
thanks again, old jim
H012 said:
The 25 amps [/color] motor start exist at the NC opening
This does not make sense. The NC contacts go to the 8 Ohm resistor and the current thru that resistor can not exceed 120V/8 Ohms = 15Amps.
The MOV should show open when the applied voltage is less than about 175V. If you measured it in the circuit with an ordinary Ohm-meter, you measured the motor resistance. If you measured it disconnected from the circuit, what did you use for a voltage source and a load?
Please do that with the AB 700CF relay since that is the one that is failing. Testing a different relay tells us nothing.
Well?
@jim hardy
But you did find a reference to overlapping AB contacts in your post #237.
i think it was 253 ?
They hide it well
http://ab.rockwellautomation.com/Relays-and-Timers/700-N-NEMA-Industrial-Relays
Allen-Bradley web page for NEMA Industrial Relays showing a 700-N relay photo and a Features list; a yellow arrow points to the item 'Overlap contacts'.
but I've yet to find anything like that for 700C
oops here it is
http://www.ab.com/en/epub/catalogs/12768/229240/229266/229661/3087130/229731/tab5.html
Rockwell Automation catalog page for Bulletin 700-CF Auxiliary Contact Blocks, listing contact arrangements, catalog numbers and connection diagrams, with a red arrow pointing to the 1L note 'Late break N.C./early make N.O.'
so i think one should verify he doesn't have the 1L contact blocks on his 700CF relay .
why they call it overlap one catalog and late break. early make in another is one of those pesky little details that drive me nuts .
yes, 25 amps thru an 8 ohm resistor with 120 volts available is curious
not that it's inexplicable but it sows doubt. Are all the wires in the right place?
