Solving Part B of e=1500*18/(1.3x10^11 x 0.000452389)
  • Thread starter Thread starter calculator20
The discussion centers on solving part B of the equation e = (1500*18)/(1.3x10^11 x 0.000452389), where the correct answer is identified as 2.8x10^-4 m. The initial calculation yielded 0.00045 due to the use of an incorrect Young's modulus value of 1.3x10¹¹ Pa, which is too low for steel. The typical Young's modulus for steel is 2.1x10¹¹ Pa, leading to the correct extension value. The user acknowledged a potential error in their textbook regarding the modulus values.
  • Understanding of Young's modulus in materials science
  • Familiarity with basic physics equations involving stress and strain
  • Knowledge of unit conversions in scientific calculations
  • Proficiency in handling scientific notation
  • Research the properties of different types of steel and their Young's modulus values
  • Learn about the relationship between stress, strain, and Young's modulus
  • Explore common mistakes in physics calculations and how to avoid them
  • Investigate the significance of units in scientific equations
Students studying physics, engineers working with materials, and anyone involved in mechanical design or structural analysis will benefit from this discussion.
calculator20
A vertical steel cable of diameter 24 mm and of length 18 m supports a weight of 1500 N attached to its lower end. Calculate a) the tensile stress in the cable, b) the extension of the cable, c) the elastic energy stored in the cable, assuming its elastic limit has not been reached.
YM steel is 1.3x10^11
E = FL/eA
I’m fine with part a, answer 3.3 x10^6 but I’m getting 0.00045 for part b when it should be 2.8x10^-4, what am I missing?
e = (1500x18)/(1.3x10^11 x 0.000452389)
I agree with your calculation.
However, note that 1.3x10¹¹ Pa (you forgot the units!) is a rather small value for the Young’s modulus of steel. There are a range of values depending on the type of steel, but 2.1x10¹¹Pa is typical value. Using this value gives the extension as 2.8x10⁻⁴m (you forgot the units!), which is the required answer.
So the mistake might be having the wrong value of Young's modulus.
Thank you for your help. I used the quoted value from the textbook but I’ve just spotted that value for copper below it is identical so it could be a mistake in the book. Thanks again
