- 16,042
- 9,255
I can't read that. There are too many erasures. Can you type it up, please?
- N(inter)=5.6x10^18 x 180 x (1-e^(-0.32x0.1x10^-3)) = 1.03x10^13 photonskuruman said:I can't read that. There are too many erasures. Can you type it up, please?
This number is too low by several orders of magnitude. The left-hand side is OK, the right-hand side is not. You must have made a mistake somewhere.meher4real said:- N(inter)=5.6x10^18 x 180 x (1-e^(-0.32x0.1x10^-3)) = 1.03x10^13 photons
i used the thickness of the paper which is 0.1 mm ?! you said that is 1 mm can you explain why ?kuruman said:This number is too low by several orders of magnitude. The left-hand side is OK, the right-hand side is not. You must have made a mistake somewhere.
The rest is ok ?kuruman said:You used the correct thickness of the paper 0.1 mm as given by the problem. What I am saying is that 5.6x10^18 x 180 x (1-e^(-0.32x0.1x10^-3)) is NOT 1.03x10^13. You need to redo this calculation correctly.
No, the rest is not Ok. Cut a piece of paper into a square of side 1 cm. Do you really believe it weighs 80 grams or 80x10^-3kg?meher4real said:The rest is ok ?
g to kg isn't 10^-3 ?kuruman said:No, the rest is not Ok. Cut a piece of paper into a square of side 1 cm. Do you really believe it weighs 80 grams or 80x10^-3kg?
- N(inter)=5.6x10^18 x 180 x (1-e^(-(0.32x0.1x10^-3)) = 3.23x10^16 photonskuruman said:You used the correct thickness of the paper 0.1 mm as given by the problem. What I am saying is that 5.6x10^18 x 180 x (1-e^(-0.32x0.1x10^-3)) is NOT 1.03x10^13. You need to redo this calculation correctly.
I agree with those numbers. Now what?meher4real said:g to kg isn't 10^-3 ?
- E(abs) = N(inter)xE(photon)
= 7.8 x 10^-3 J
What's wrong with weight 80x10^-3kg ?kuruman said:I agree with those numbers. Now what?
weight x 1 cm^2 ?kuruman said:A standard, letter-sized 8.5"×11", sheet of paper weighs 4 to 5 grams. Do you really believe that if you cut a square piece 1 cm on the side out of that sheet, it will weigh 80 grams?![]()
The whole sheet of paper is 4 grams. If you cut a piece of that paper any size, any shape, can it weigh 20 times as much as the entire sheet? Think!meher4real said:weight x 1 cm^2 ?
huh you're right, weight/1cm^2kuruman said:The whole sheet of paper is 4 grams. If you cut a piece of that paper any size, any shape, can it weigh 20 times as much as the entire sheet? Think!
I found Energy required to heat paper = 0.40 Jkuruman said:So what is the mass of 1 cm2 of paper? Read carefully and understand what you are given.
I didn't ask you what energy is required to heat the paper and I didn't ask you for the number of photons required. I asked you to find the correct mass of the paper that is heated up. You have repeatedly avoided answering my questions which I am only asking to guide your thinking. Your refusal to answer them indicates to me that you reject my help. If that's the case, I will stop helping you.meher4real said:I found Energy required to heat paper = 0.40 J
number of photons required = 1.612x10^18 photons
Not at all !kuruman said:I didn't ask you what energy is required to heat the paper and I didn't ask you for the number of photons required. I asked you to find the correct mass of the paper that is heated up. You have repeatedly avoided answering my questions which I am only asking to guide your thinking. Your refusal to answer them indicates to me that you reject my help. If that's the case, I will stop helping you.
