Solving Rocket Launch at 75 Degrees After 11.2s
A rocket launched at a 75-degree angle accelerates at 21.4 m/s², and the goal is to determine its position after 11.2 seconds. The solution involves breaking down the acceleration into x and y components, with x acceleration unaffected by gravity and y acceleration adjusted for gravitational effects. The equation d = vt + (1/2)at² is crucial for calculating displacement in both directions. After applying these principles, the final positions are calculated as Xfx = 353.7 m and Xfy = 693.4 m. Understanding how to incorporate gravity into the y-direction is essential for accurate results.
HomerPepsi
A rocket is launched at an angle of 75 degrees and accelerates at 21.4 m/s^2. Where is the rocket located (from the point of origin) after 11.2 seconds?
a=(vf - vi) / t
(vf + vi) / 2 = (xf - xi) / t
where: vf = velocity final, vi = velocity initial, xf = displacement final, xi = displacement initial, and of course a = acceleration and t = time
given solution: Xfx = 353.7 m; Xfy = 693.4 m (don’t forget gravity in the y-direction)
X
ax = 21.4cos75 = 5.54
vix = vi cos75
vfx= vi cos75
xfx = ?
xix = 0
t = 11.2
Y
ay = 21.4sin75 = 20.67
viy = vi sin75
viy = ?
xfy = ?
xiy = 0
t = 11.2
any one got any Ideas to the path to the solution, and how do i account for gravity? add/subtract?
thanks
I believe your main problem is that you don't have the equation
d = vt + (1/2)at^2 ; where v is initial velocity, t is time, and a is your acceleration.
Once you break the acceleration into it's x and y components, you should be able to get both the x and y distances with the above formula.
Also one thing to note is that the acceleration in the x direction doesn't get effected by gravity, and the acceleration in the y direction is the difference between your original acceleration and gravity. (i.e initial velocity - gravity)
