Solving Sin(A)=Sin(B): Where did the 2nd Solution Go?
  • Thread starter Thread starter C_Ovidiu
The discussion focuses on the equations involving sine and cosine relationships between angles A and B, with a particular emphasis on the solutions derived from sin(A) = sin(B). The user identifies that while solving sin(A) = sin(B) leads to the conclusion that A = B, it only results in b = c, missing the second solution of a^2 = bc. The conversation highlights that A and B can have different values despite b and c being equal, illustrated by specific examples. Visual aids, such as plots and triangle diagrams, are suggested to better understand the relationships between the variables. The overall conclusion is that the angles A and B are not uniquely defined and can be complementary without a specific solution.
C_Ovidiu
Say we have the ecuations below a,b,c positive numbers
sin(A)=a/sqrt(a^2+b^2) 1
sin(B)=a/sqrt(a^2+c^2) 2
sin(A)cos(A)=sin(B)cos(B) 3
I realized that calculating cos(A) and cos(B) and then solving the third ecuations i get the solutions b=c and a^2=bc
But solving only sin(A)=sin(B) ( we get form 3 that A=B ) I get only b=c . I'd like to know where did the second solution go ... ??
Mathematics news on Phys.org
did anyone suggested you of latex format
Nobody ( just) did
sin(A)\ =\ \frac{a}{\left(a^{2}+b^{2}\right)^{\frac{1}{2}}}
sin(B)\ =\ \frac{a}{\left(a^{2}+c^{2}\right)^{\frac{1}{2}}}
sin(A) \times cos(A)\ =\ sin(B) \times cos(B)
Did it for you :P
Tks. I shall learn this latex .
It is not really true that b=c, or that A=B. They could be equal, but there are many solutions where they are different, for example a=sqrt(3), b=1, c=3, A=60 deg, B=30 deg.
If you draw a plot of the function f(x) = sin(x)cos(x), it could help you to visualize the relation between A and B (and thus between b and c).
Also, since a,b,c > 0, you can draw them as line segments, so it might help to draw a picture with triangles that represent eq. 1 and 2 (and where b is not necessarily equal to c).
one thing is clear seeing the eq. they certainly represent the right triangle with a perpendicular dropped on hypotensue
a=length of perpendicular
b,c sides
i hope their is no specific solution for the angles
they are just complementary
don,t go by it it is just a guess , no calculations
