Solving "tanθ + cotθ = 2": Is it Wrong?
  • Thread starter Thread starter BOAS
The discussion revolves around solving the equation tanθ + cotθ = 2 within the range of -180° to 180°. The original approach involved manipulating the equation using trigonometric identities, leading to the realization that 2cosθsinθ = 1. This was identified as a critical step, as it simplifies to sin2θ = 1, yielding solutions of θ = 45° and θ = -135°. Participants noted that an alternative method using the quadratic form of the equation is more straightforward and confirms the same solutions. The conversation highlights the importance of correctly applying trigonometric identities to solve equations effectively.
BOAS
Hello,
i'm fairly sure that what I have done is wrong/not allowed, but I want to check because it seemed like a good idea, but now it's causing problems.
Solve the following equations in the range -180°≤ θ ≤ 180°
tanθ + cotθ = 2
tanθ + cotθ = 2
\frac{sin\theta}{cos\theta} + \frac{cos\theta}{sin\theta} = 2
\frac{sin^{2}\theta}{cos\theta sin\theta} + \frac{cos^{2}\theta}{sin\theta cos\theta} = 2
\frac{sin^{2}\theta + cos^{2}\theta}{cos\theta sin\theta} = 2
sin^{2}\theta + cos^{2}\theta = 2cos\theta sin\theta
Since sin^{2}\theta + cos^{2}\theta = 1
then
2cos\theta sin\theta = 1
(the above is where I think I've done something careless)
I now have
I don't know what to do with it really... I tried saying sin^{2}\theta = 1 - cos^{2}\theta but it doesn't really get me anywhere.Is what I have done not correct?
EDIT - I know it can be solved by putting the original equation into a quadratic form, and doing so did bring me to the correct answer of -135 and 45 degrees.
Well, manipulating the original equation gives 2cosθsinθ = 1. What you need to do is find θ to make this equation true.
Ahhh, I was focused on the other side of the equation!
2cosθsinθ = sin2θ
sin2θ = 1
2θ = 90
θ = 45
from the curve I can see where -135 comes from also.
It's quicker to replace cot(θ) by 1/tan(θ)
tanθ + cotθ = 2
tanθ + 1/tanθ = 2
Multiply by tanθ to get
tan2θ + 1 = 2tanθ
tan2θ - 2tanθ + 1 = 0
This equation can be factored to solve for tanθ.
BOAS said:
Hello,
tanθ + cotθ = 2
tanθ + cotθ = 2
then
I now have
The quantity ##t = \tan(\theta)## must satisfy the equation
t + \frac{1}{t} = 2,
whose unique (real) solution is ##t = 1##. This is easy to see and prove. For any ##A,B > 0## the arithmetic-geometric inequality says
\frac{A+B}{2} \geq \sqrt{AB},
with equality only when ##A = B##. Apply this to ##A = t, B = 1/t, ## to conclude that for ##t > 0## we have ##t + 1/t \geq 2,## with equality only when ##t = 1##. For ##t < 0## it similarly follows that ##t + 1/t \leq -2,## so negative values of ##t## won't work.
So, the unique root is ##\tan(\theta) = 1##.
tanθ + cotθ = 2
tanθ + 1/tanθ = 2
tan2θ + 1 = 2tanθ
This is how I solved it after struggling with the method outlined in the OP.
Much simpler, but it is cool to see the many ways of solving these problems.
BOAS said:
Hello,
tanθ + cotθ = 2
tanθ + cotθ = 2
then
Yes, you've said that \frac{sin^{2}\theta + cos^{2}\theta}{cos\theta sin\theta} = 2
and sin^{2}\theta + cos^{2}\theta = 2cos\theta sin\theta
Now, substitute the 2cos\theta sin\theta into the numerator of \frac{sin^{2}\theta + cos^{2}\theta}{cos\theta sin\theta} = 2
This will give you \frac{2cos\theta sin\theta}{cos\theta sin\theta} = 2
which simplifies into 2 = 2
BOAS said:
2cosθsinθ = sin2θ
sin2θ = 1
2θ = 90
θ = 45
sin(2θ)= 1 when 2θ =90 °+ k 360 °, k=0, ±1 ±2... . That means θ=45 ° ± k 180 °. Which angles are in the range [-180°, 180°]?
ehild
So? The idea is to show that tanθ + cotθ = 2, not that 2 = 2, which is obviously true.
