SBaldrick
- 5
- 0
Hello, my name is Eugene, i am glad i found a forum for people who love math.
I was reading a book on mathematical puzzles recently, and there was one which i couldn't solve, mostly because i am not a very clever guy. Perhaps you will have some ideas?
The area of the puzzle is non -linear algebra and number theory.
The author talks about a following situation. We have a machine, which can accept input (an integer) , and produce an output (also an integer) depending on the input.
We know, that calculations inside the machine are following:
F(x) = ( a0 + a1*x1 + ... + a7*x7 ) MOD M
But we don't know modulo or coefficients. However, M, ai, x must be between [0, 65535]
the goal is to find out all ai coefficients and modulo M;
We can calculate F function arbitrary number of times for any argument we want .
Now, my ideas so far were:
1) We can build a system of linear equaions (8 of them), for x between 0 to 7, and solve it with Gaussian reduction, or with Kramer rule. This would give us all coefficients easily.
For instance (slightly shorter example)
let the inner state of the machine be: F(x) = a0 + a1x + a2x2
a0 = 3
a1 = 7
a2 = 2
then F(1) = 12, F(2) = 25, F(3) = 42 and the system of equations is:
a0 + a1 + a2 = 12
a0 + 2a1 + 4a2 = 25
a0 + 3a1 +9a2 = 42
and by applying the Kramer rule we get the correct values of coefficients, 3, 7 and 2.
But we have a problem - modulo M.
Now if M is a prime (13 for simplicity) : the system changes -
a0 + a1 + a2 = 12
a0 + 2a1 + 4a2 = 12
a0 + 3a1 +9a2 = 3
And the results would be 3, 13.5 and -4.5
Result is in the same class modulo M as the original coefficients, and we can obtain original:
13.5 = 27/2 (mod 13) = (27 + 13) / 2 = 40/2 = 20 (mod 13) = 7
in the same way:
-4.5 = -9/2 ( mod 13) = (-9 + 13) /2 = 4/2 =2
And we can find inside state of function F. This however, needs the modulo to be known.
But if the modulo M is not prime (say 14), for the system above results would be:
3, 14, -5 or after doing the modulo operation : 3, 0, 9
Now, the answer is not correct (the inside state of F function are different).
So, i am having trouble with this bit.
I understand, that if we calculate all possible results for all 60 + thousand inputs, we will have a table with which we can recreate the F function.
But the author states that there is a more brilliant solution, which requires lesser amount of computations.
Do you find it interesting? Perhaps you would also like to know the answer? The author calls this puzzle a "black box"
Lets try solving it together!
regards, S. Baldrick
a0 = 3
a1 = 7
a2 = 2
a0 + a1 + a2 = 12
a0 + 2a1 + 4a2 = 25
a0 + 3a1 +9a2 = 42
a0 + a1 + a2 = 12
a0 + 2a1 + 4a2 = 12
a0 + 3a1 +9a2 = 3
in the same way:
