Solving the Friction of a Crate on a 20° Plane
  • Thread starter Thread starter laxboi33
    Friction Plane
A crate on a 20° incline with static and kinetic friction coefficients of 0.45 and 0.35 is analyzed for acceleration. The net force is calculated as the difference between the gravitational force down the incline and the force of static friction. The initial calculations suggest a negative acceleration, indicating the crate does not move. The discussion emphasizes the need to determine if the static friction can counteract the gravitational force before concluding the crate's motion. Ultimately, the static friction's maximum opposing force must be compared to the net force to ascertain if the crate remains stationary or slides down the incline.
laxboi33
A crate is on a 20 degree plane where the coefficients of static and kinetic friction are .45 and .35 respectively. What is the acceleration of the crate?
Mk= .35
Ms= .45
F= sin20 * mg (I think this is the net force?)
F - Fk= M*A
(sin20 * mg) - (.35 * mg) = m * a
a = sin20 * g - .35 * g
a= .34 * 9.8 - .35 * 9.8
a = -.098
The answer in the book says 0. As I was writing this problem I think I figured it out. If sin 20 is the net force, then that would make net force less than the static friction which would give it 0 acceleration. Maybe I just miscalculated the net force. If so could someone explain to me what net force would be for this equation? Thanks, guys.
You presupposed that the crate slides down the incline.
You must first check to see if it starts moving at all!
The static friction force is a reaction force. It will always oppose the total sum of the forces parallel to the surface it acts from.
The only force in the direction of the incline, other than friction, is as you've pointed out, mg\sin{\theta}
Now, the force of static friction tries to oppose this. Can it? What is the maximum force that the static friction can oppose? Is the total force it has to oppose less than, or more than this limit?
thanks cat
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
