Solving the Gravitational Problem: Rocket Speed at Great Distance from Earth"
  • Thread starter Thread starter SELFMADE
    Gravitational
A rocket launched from Earth's surface at 15,000 m/s will experience a change in speed as it moves away from Earth. The escape velocity from Earth is 11,200 m/s, meaning the rocket exceeds this speed upon launch. However, determining the speed at a great distance from Earth requires considering gravitational effects and energy conservation. The initial kinetic energy and gravitational potential energy must be balanced to find the final speed. Therefore, the problem emphasizes the need for a deeper understanding of gravitational dynamics rather than a simple calculation.
SELFMADE
A rocket is launched straight up from Earth surface at 15000 m/s speed. What is the speed of the rocket when its very far away from the earth?
Escape speed from Earth is 11200m/s. So I am guessing the rocket's speed when its "very far" away from Earth is 3800m/s?
Nice try, but no, that's not the answer. This problem is not quite that simple.
Think about this: how do you calculate the escape velocity, 11200 m/s? That should give you a clue as to how to proceed with this problem.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
