Solving the Kinetic Friction and Tension of Two Blocks
To solve for the coefficient of kinetic friction and the tension in the rope connecting two blocks, a free body diagram is essential to visualize the forces acting on each block. The problem states that the blocks are moving at a constant velocity, indicating that the acceleration is zero. This means that the net forces acting on the blocks must balance out. The equations of motion should incorporate the gravitational force, normal force, friction, and tension to find the required values. Properly accounting for all forces will lead to the correct calculations for both the coefficient of kinetic friction and the tension in the rope.
mooney82
Block A (M1-5 kg) is on a horizontal surface and block B (M2-2 kg)to the left resting on a 30 degree incline. the two are connected to each other by a mass-less rope over a massless pulley and are moving down hill (to the left) at constant velocity.
a) Find the coefficient of kinetic friction assuming it is the same for both blocks.
b) The tension of the rope
fk=ukN
I found -fk=M1*a and substituted that into the first equation of 5sin(30)-fk=ma. I'm not sure if I'm even starting this right or not, a gentle nudge in the right direction would be most appreciated.
mooney82 said:
I found -fk=M1*a ...
You are omitting one of the forces acting on the mass. Did you draw a free body diagram ?
Another hint: from reading the problem statement, we know that a=____?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
