Solving Trig Identity Problem: Asin^2(wt) + Bcos^2(wt) = A = B
  • Thread starter Thread starter DiracPool
    Identity Trig
The discussion revolves around the equation Asin^2(wt) + Bcos^2(wt) = A = B, questioning its correctness and derivation. Participants clarify that while sin^2(wt) + cos^2(wt) = 1, the relationship between A and B is specific and not a general identity. The equation represents total energy, which must remain constant due to conservation principles, rather than being a straightforward trigonometric identity. It is emphasized that A and B are not inherently equal, but can be equal under certain conditions related to energy conservation. The clarification highlights the need for context to fully understand the derivation presented.
DiracPool
I can't quite work out this derivation I ran into which is essentially...Asin^2(wt) + Bcos^2(wt) = A = B. Is this correct?
I know that sin^2(wt) + cos^2(wt) = 1, but I can't reason out how the factoring works here? Any help?
Mathematics news on Phys.org
Where exactly did you run into it? Can you paste some context for us to look at?
Looking at what you wrote, as long as A = B, the full statement is true... but if that's the case, then you might as well just use A.
Actually, you can can find the full equation here at the bottom of the screen at 1:20 -
So A and B are not the same. In effect, its Asin^2(wt) + Bcos(wt) = constant, where the constant is Energy in this case, but the guy doesn't do the deriviation, he just presents the equation and I'm not clear on how he factored it.
I think you are misunderstanding what he is saying. It is not that "A sin^2(x)+ B cos^2(x)" is a constant- it is only for these specific, and related, A and B. And he is not using any trig identity. He is simply stating that the "A sin^2(x)+ B cos^2(x)" is the total energy and, because of "conservation of energy", must be constant. Of course, taking x= 0 gives "B" and taking x= pi/2 gives "A" so A and B must be equal to that constant and so to each other.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
18K
