Solving Vector Equation: (2i - 3j + 4k) X A = (4i +3j - k)
  • Thread starter Thread starter skiboka33
    Product
The discussion revolves around the validity of a student's claim that a vector A exists such that the cross product (2i - 3j + 4k) X A equals (4i + 3j - k). Participants emphasize that the resulting vector from a cross product must be perpendicular to both original vectors, leading to a dot product of zero between the vectors involved. However, the calculated dot product in this case is -5, indicating that the claim is likely false. To verify the existence of vector A, one can set up equations based on the components of the cross product and solve them simultaneously. Ultimately, the conversation highlights the importance of understanding both geometric and algebraic perspectives in solving vector equations.
skiboka33
Kind of a weird question , don't really understand it:
"A student claims to have found a vector A such that:
(2i - 3j + 4k) X A = (4i +3j - k). Do you believe this claim?
thanks for your help...
Mathematics news on Phys.org
You need to see if you can find some vector A, such that the given cross product is valid. Simply compute the cross product for a general vector
A = (A1,A2,A3)
Does this vector exist?
Alternatively, try to apply the fact that the cross product of two vectors is perpendicular to both of the vectors crossed.
yeah, just seems like for any two crossed vectors there will always be one perpendicular to both of them, isn't that the case??
Yes,the three vectors involved in:
\vec{A}\times \vec{B}=\vec{C}
form a trirectangular trihedron...I hope u know that you problem assumed solving a 3-3 algebraic system...
Daniel.
So, since the reputed cross product must be perpendicular to both the other two vectors, the dot product between the (reputed) cross product vector and the other vector you know must be..?
The cross-produkt of two vectors is always perpendicular to both the vectors of which you calculate the cross-produkt.
in:
v1 \times v2 = v3
v3 is perpendicular to both v1 and v2
the dot-produkt of two perpendicular vectors is zero, so in your case
(2, -3, 4)\cdot(4, 3, -1)
should be zero, but it is -5.
Calculate the cross product of your first vector and A.
You'll end up with 3 equations, one for each component.
Set these equations to equal the respective components of your final vector.
Then try and solve the equations simultaneously.
If there is a solution, then the vector A exists.
It's the same advice i gave...It leads to the result,eventually...Unforunately for us,there's a much shorter and "brighter" way.Both Arildno and Gerben pointed it out...
Daniel.
Of course calculating the dot product is a much easier way to solve the problem.
However, I think it is useful to show that there is more than one way to skin a cat, especially when they don't seem to grasp the first method.
