Solving Electricy Probs: Determining Resistance & Current + Circuit Diagram
  • Thread starter Thread starter shemer77
The discussion revolves around solving a homework problem involving a 120V battery, a hair dryer rated at 1200W, and a mixer rated at 120W designed for 60V. Participants are tasked with determining the resistance of both devices, calculating the current in the mixer, and creating a circuit diagram to operate both simultaneously. The hair dryer’s resistance is confirmed to be 12 ohms, while the mixer’s resistance can be calculated using the same power equations. Participants are encouraged to consider series and parallel connections to manage voltage requirements and to calculate the total power needed from the battery. The conversation highlights the challenge of applying electrical concepts to practical problems.
shemer77
You are given a 120 V battery; a hair dryer designed to work properly at 120V, where its rated at 1200 W; and a mixer designed to work properly at 60v, where its rated at 120W. You also happen to have a supply of 60 ohm resistors.
a) determine the resistance of the hairdryer and the mixer at their rated voltages
B) what current is established in the mixer when its working properly
C) using the symbols shown, draw the connections needed to make both devices work simultaneously
Symbols
a resistor
a battery
a box with the letter h signfiying hair dryer
and a box signifying mixer
d) what power must the battery supply to run your circuit?
a)I think the resistance of the hairdryer is 12, but how would I found the mixers?
B) don't know how to approach this one?
c) same as above
d) wait wait... nope, don't know how to this one either.
My teacher likes to assign homework on stuff we havant learned yet :(
How did you find out the resistance of the dryer? Is there an equation for power in electrics?
c) same as above
Power = VI = I2R = V2 / R
A) The hairdryer's internal resistance is correct. The mixer's internal resistance can be found the same way.
B) When the mixer is working properly you know the voltage across its terminals is 60 V and you know how much power it is consuming, 120 W. You found the mixer's internal resistance in part A. See the above power relationships.
C) You know the voltages both of the devices need to operate at, and you know the source voltage, 120 V. Also, you have 60 ohm resistors to use to cause voltage drops in parts of the circuit. Think about parallel and series connections.
D) Once you have designed the correct circuit, you just need to come up with an Req and determine the source current. Then see the above power relationships.
thanks, solved this one easy. Just needed the right push.
